| Team Camaro Tech Current Topic: 69 z28 302 fuel pump to carb line install? | ||
| Restoration Corner Where originality comes first |
I am getting rid of the braided carb lines that came with the car and going back to original lines - are they hard to install - i don't want to tweek the main line if possible - do i need to remove the water pump or hoses --- where dose the fuel line hold bracket mount too --
Thanks Bob ps also - where does the passenger (right side ) engine lift bracket mount too ---- |
| Sponsored Links | ||
Advertisement | ||
Not hard at all. I believe you can get it through the water pump without having to take it off. I don't have the fuel line bracket installed. I'm pretty sure the pass engine lift bracket mounts to the last intake bolt because the wire harness mounts to the 2nd intake bolt.
Dennis 69 Z/28. 302DZ, Autogear M22, Red w/black stripes. 69 Camaro, ZZ4, TH350. 8.5 3:42 posi, X11 87 IROC |
great pic - i don't have the part in hand and my engine guy want sure of all the bends - wants to finish assembly tonight but the part comes friday - those darn back orders - looks like i can turn it 90* and slide down past the pump - guess i'll return the bracked - don't see a need
thanks again for that pic Bob |
You may need to change the fuel inlet fittings on your carb. All the fuel logs and newer carbs out there seem to be a different size than the orig stuff. I don't have a 302 but had a 780 carb and Z/28 hard lines and Y block. I switched to a 670 Avenger and had to switch the fuel inlet fittings on the 2 carbs...
i bought the repro 4053 list holley - hope the fitting fit - i have the lines and yoke from the old carb to work with - only the yoke to pump was braided
B |
They should fit. The picture above is the Holley your talking about from Heartbeat City.
| Sponsored Links | |
Advertisement | |
Similar Threads
| 69 z28 302 pump to carb line installation? | Bob69z28x77 | Camaro Tech | 0 | Jun 5th, 07 10:23 AM |
| correct 69 fuel line DZ | trezpan | Camaro Tech | 3 | May 26th, 07 02:18 PM |
| Fuel pump line size for early 67? | erik67ssrs | Engine | 4 | Apr 12th, 07 12:18 PM |
| Wiring Issue After Engine Swap Help Please!!!! | tourville87 | Camaro Tech | 7 | Nov 20th, 06 06:52 PM |
