EFI in your modern Classic EFI conversions in FirstGen Camaros
Old Jun 6th, 07, 09:11 PM
bri-rock's Avatar
bri-rock bri-rock is offline
Tech Team
Default I'm on the fence on going to EFI... help push me over.
My most recent plan had been to get a crate 383 with a carb for my 67 coupe. My plan was to run a high compression (13 to 1) with the idea that I would be able to run E85 (higher octane at 103+). Why? Call it a political statement. Call it a challenge. Whatever it is, I want to do it. Short-term, however, there are almost no stations selling E85 on the west coast. I thought, "well, I'll just run water injection on the above set-up which is proven to work with real high pressures (turbos, etc).
Well, a buddy at work (whose opinion I respect on cars) thinks I have rocks in my head for not considering an LS1. He thinks that its the best power for the money, plus the added control. Anyway, I'm worried that going this way would completely eliminate the possibility of running E85 in the future.
Okay, so there it is, someone push me off this fence...
Old Jun 6th, 07, 09:21 PM
Lance-w Lance-w is offline
Gold Member
Default Re: I'm on the fence on going to EFI... help push me over.
400 hp and 25 mpg. I'm sold. I bought the entire 200 LS1-T56 combo for $3500. It'd cost that much for the 383. I want to build a car I can take on long trips. The mileage potential sold me.
Old Jun 6th, 07, 11:05 PM
bri-rock's Avatar
Tech Team
Okay, so the price is right and the performance on pump gas is great. What about the alternative fuel part? Any companies deal with this on EFI?
Old Jun 12th, 07, 07:35 PM
Doug F. Doug F. is offline
Tech Team
I haven't personally done an E85 EFI conversion, but just get the parts compatible with ethanol fuel (hoses and metal) and get some injectors that are about 60% or so larger than you'd use with gas and you should be ok, especially if you get a wideband sensor compatible that reads E85.
Old Jun 12th, 07, 10:43 PM
bri-rock's Avatar
Tech Team
Thanks to all for the replys. I have since found about three different companies that sell aftermarket EFI systems that can be adapted to run as flex fuel. There is sensor in the fuel line that determines the ethanol percentage and the pulse duration is extended or shortend accordingly for the injectors. As mentioned above, the injector size needs to be changed also and the metals and any hoses, gaskets must be compatible. I think I'm sold on going to EFI. Now, I'm just shopping for a good price on a used LS1.
Old Jun 13th, 07, 06:31 AM
Rich-Allen Rich-Allen is offline
LS1 engines are a dime a dozen.
Call some wrecking yards and get a complete motor with all the electrical (ecm, harness)
You should be able to pick something up for around $1500.
AFR Heads W/ Jesel valve train
http://www.fquick.com/Rich-Allen
67 RS / SS
http://eastbayerectors.com/camaro.html
Old Jun 13th, 07, 07:50 AM
Gold Member
This is a great place to learn about the swap. http://www.ls1tech.com/forums/forumdisplay.php?f=28
This is someone that is currently doing a swap into a 67 RS/SS. Good reading and lots of pictures.
http://www.ls1tech.com/forums/showthread.php?t=684612
Also beware there's a lot of incedental "gotta have this to make that work" type cost associated with swapping. I haven't by any means spent all the money I'm going to need to for the swap but I would venture to say that buying the motor is only about half the cost or less than half the cost. For example to do the fuel system the "right" way you really need to buy a aftermarket tank. "THE" aftermarket tank to get costs $1100 for a flippin gas tank. There's people doing the fuel system other ways but the right way is with the tank designed for EFI. Do your research on the LS1tech site before you jump......
Old Jun 20th, 07, 07:20 PM
CGFlyer61 CGFlyer61 is offline
Gold Member
Dan
The guy over on LS1Tech mentioned he was very satisfied with a supplier in SC. I didn't copy the name down, but it is in the very detailed thread. I think he finally got the car running right just a couple of days ago. That is definitely the way I'm leaning with my 6 cyl 'vert. I can't wait for winter!
Dan
Old Jul 14th, 07, 11:51 AM
scblucam's Avatar
scblucam scblucam is offline
Team Member
Scott
In my humble opinion E85 is a scam to benefit Archer Daniels. It gas raised the cost of beef and chicken. And have you seen the cost of tacos?
Not to mention that it uses more power to create than it provides.
Old Jul 21st, 07, 08:36 PM
Joe G Joe G is offline
Amen brother!
Joe G
69 Coupe; ZZ430; TKO600; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Carrera coil-overs front; Classic AutoAir AC and power windows now cuz I'm old and lazy!
Old Jul 22nd, 07, 05:10 PM
DOUG G's Avatar
DOUG G DOUG G is online now
Agreed.
You only get ???? 60% ???? or so mpg (E85 Vs. gas)
Doug G.-406ci
Camaro Pics ~ AKA: RedЯum
1.643 - 60'
7.511 @ 91.33 -660'
11.823 @ 113.52 -1320'
Old Jul 24th, 07, 10:42 AM
Rhino Rhino is offline
Ryan
Originally Posted by DOUG G View Post
Agreed.
I think what scblucam meant is that it takes more BTU to produce a gallon of E85 than the BTU it produces. When you're figuring the total BTU involved (including incidentals such as diesel for tractor/combine/spray rig fuel, fertilizer production, transportation, etc...) you burn more energy than the fuel provides. You end up with an energy deficit.
I do, however, agree with your decreased mileage comment as well.
Old Jul 24th, 07, 07:14 PM
scblucam's Avatar
Team Member
Scott
Not to mention that even with E10, if you are a boater with a fiberglass tank you risk not only clogging your filters, but turning your boat into a fire ball because many of the resins previously used are eaten by the alchohol causing the tank to leak into the bilge. Reference Boat US magazine from a couple of months ago with the story of a Senators megaboat severely damaged. I have had fuel problems since it was intriduced. I don't want to get political here but this is wrong.
Old Jul 27th, 07, 12:32 AM
Rodder's Avatar
Rodder Rodder is offline
Team Member
Jon
The next big scam is hydrogren... the only cost effective way to produce mass quantities of hydrogen is steam reforming of natural gas. It's cheaper and more efficient to just burn the friggin natural gas in the first place, and it doesn't do squat for the economy in the big picture since we're already having to import natural gas to supplement domestic supplies. There are some people working on algae that produce hydrogen, but I haven't seen anything economically viable yet.
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Old Jul 27th, 07, 01:16 AM
EvilZ28 EvilZ28 is offline
This always seem to make me laugh, But it seems every power source that is safe for the environment is usually released or produced slowly. In todays fast world, we need energy now!!! So when a process is increased in speed that used to be harmless, seems to either make pollutants which are harmless or becomes deficient meaning it takes more energy to make then worth. I am in no way saying this is true but it just seems to be the way it always goes. Look at the Hybrid. Proven studies have shown that your are really not saving any money driving one in the way of fuel efficiency. Just in tax dollars. Again just what I have noticed. Going back to the question at hand. Go with the Injection, You will be very happy. I have a 383 LT1 Supercharged, and Intercooled. Best time on her is 9.80 and it is in a 95 Transam. The nice thing is I can drive it and I get around 19 miles to the gallon. Not to bad with 60 LBS injectors. I also am installing a LS2 in a 69 Nova as for the Fuel Mileage, Reliability, And it does run cleaner then a Carburetor. Not that I am a tree hugger or anything. LOL Mainly for the power. : )
Similar Threads
are my push rods to small? MY FIRST 69 Engine 3 Aug 1st, 06 09:44 PM
are my push rods to small? MY FIRST 69 Engine 2 Aug 1st, 06 05:52 AM
EFI small block engine build, need advice Camaro76350 Performance 0 Jan 15th, 06 10:59 AM
Push rod snapped joe clance Troubleshooting 1 Jul 4th, 01 10:07 AM
