| Team Camaro Tech Current Topic: 6 speed | ||
| Pro Touring Todays performance with classic style |
Hi all,
I just purchased a 1969 Z11 Pace Car with no motor or transmission. It's a really solid car needing a restoration that shouldn't be too terribly painful. I believe the car to be an original 350 automatic car but since I don't have the original running gear I want to change the car a bit to my likings; a powerful cruiser. I have a 600 + hp 502 and I would like to put a 5 or 6 speed manual transmission behind it. What I need to know is how difficult is it to mate this transmission up? I'm concerned about bellhousing, or other issues I may not be aware of, (do these later model trannies require any special wiring etc...), I would love an overdrive option but is it a can of worms that could get ugly? Any tips or advice would be greatly appreciated or if there's a website that might help me eliminate some potential pitfalls that would be great to. Lastly, I also have a 1969 375 hp 4 bolt main block that is a factory CE stamping, (warranty replacement), do you think the 502 and 6 speed will hurt the car's value over a correct dated 396 and munice? Thanks in advance all! |
My opinion is make it how you want it and find the original drivetrain if possible and store it. A beefed up ls1 should bolt right to your application. Really not many problems with the install. Do a search for Mkelky.
the learning curve is....expensive
So will using Big Block motor mounts cure the header steering box problem? Yes I'm keeping this car for myself, but I also know the reality that sooner or later, (probably MUCH later), it will be sold but I want it the way I like it in the meantime but I don't want to destroy the car either. I want to set it up so it's a simple engine/trans swap and go back vintage stock. Possible?
its worth alot more as an original PACE CAR. i have had my eyes on a 69 z11 396 big block in need of serious body work, but all original. I 've already been rejected up to $20K. I visit it every 6 months and up the offer. I'll either have it or have to forget it within 2007. Meanwhile i enjoy my modified X-44 base car. i wouldn't have the time or motivation to acquire, store and re-do the same car over again, back and forth to mod to original , or vica-versa.
Its a real delemma when the car is so valuable in its original state.
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers. |
Are you thinking about a used Camaro 6 speed? They use a hydraulic throughout bearing that would require a bracket and slave cylinder. Why not go with a Tremec TKO 600 with the .64 overdrive. A great trans that will bolt right up to your existing bellhousing and use existing bellcrank, etc. Only requires shortening the drive shaft.
I also agree with Joe Dance. The car would be worth a lot more with the 396 and the Muncie. So keep them on the side until you decide to sell the car...if that day ever comes. |
'69 ZZ502, Holley Commander 950 MPFI, Tremec T56, Dana 60 |
The tremec seems to be a good complete kit that would pretty easy to install. I think I'm leaning that way, $3000 is not cheap but probably worth it in the long run.
You might find some useful information here: http://www.camaros.net/forums/showthread.php?t=98387
Mike - 68 Camaro with some stuff done to it; building another '68 with even more stuff done to it. http://www.camaros.net/forums/attach...2&d=1176782254 |
Craig Wright at www.wrightconnection.net specializes in exactly this. You might give him a shout and see what he thinks. Hope this helps!
Similar Threads
| 3 Speed to 4 Speed Muncie | Fewski | Transmission & Driveline | 3 | May 1st, 07 06:05 AM |
| 3 Speed or 4 Speed? | Fewski | Tag Team | 4 | Mar 26th, 07 07:15 AM |
| speed sensor not working | jimijam | Transmission & Driveline | 1 | Sep 19th, 05 04:37 PM |
| What parts are needed to convert 69 AT console to 68 4 speed | Winch | Interiors | 0 | Sep 19th, 05 07:32 AM |
| What gearing to run with my stall? | Luke805 | Performance | 23 | Oct 15th, 02 05:22 AM |
