| Team Camaro Tech Current Topic: Jim's efi conversion | ||
| EFI in your modern Classic EFI conversions in FirstGen Camaros |
having a pretty lazy saturday, but the rain finally stopped.
I've purchased a used Holley system from member Paulm, great price, kit looks only slightly used and very complete. It's a 900 cfm 4 BBL TBI, with v3 pro commander 950 controller. I'm about to go in the garage, put power to the c950 and hook up the laptop and see what she has to say. I'll be sure to post come pics. But first a question. I installed the software that Paul emailed me and fired it up. It is version 1.2. I think that is old, and I can't find the wideband checkbox or the voltage / afr table. I'm pretty sure I know my way around this stuff enough to find it if it was there (but could be wrong) Can anyone zap me the latest s/w for this thing? It's the same for any holley pro system.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI 04 Silverado SS The Black Beast 93 Polo Green Corvette http://www.Jimragtop.com Jim's NEW Blog! Jim Cam Last edited by JimM; Jun 23rd, 07 at 04:41 PM. |
well, I did talk t paul, and he's gonna zip me the newer s/w, but...
I have my doubts that this thing is even powering up? It's laid out on the bench, most everything hooked up. I connected the "bat" and "IGN" leads to the + side of a battery, the black ground wire to the _ side of the battery, even ran a ground from the base of the ECU. The PC won't talk to it, acts exactly the same as if the cable wasn't hooked up at all, says ecu powered off or cable not connected. could be the wrong s/w, tho I'd think it would at least see it. Could be the usb to serial cable, I'll try it later on an older laptop with a serial port. Could be wrong serial settings, holley book says NOTHING, I'm set to 9600, 8 none 1 The thing that's kinda bugging me is you'd think if the ecu was powered up and the ign was on, the output to the injector power relay would be 12 volts, and it's not. I also monitored the fuel pump output while i conected the ign lead, again, nuttin.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI 04 Silverado SS The Black Beast 93 Polo Green Corvette http://www.Jimragtop.com Jim's NEW Blog! Jim Cam |
Jim I assume that you confirmed your serial port on the laptop is not disabled. Right click my computer, properties, hardware, device manager, com ports. Anything with an X
-Doug 68 RS/SS Conv Restoration started 5/25/07. Have it for spring 08? Motor is finally done (3/8/08) Have it by summer 08? Nope Have it by fall 08? Nope Have it by Winter 08? No way Have it by Spring 09? Nope but its made it the the body shop..... Have it for Summer 09? Possible |
My laptop doesn't have a serial port, only usb. I'm using a usb to serial cable and driver that I have used successfully in the past with other programs. It lets me assign it to com 1 - 4, I've tried 1, 2 and 4...
I use a USB/Serial adapter on lots of stuff. It works with my laser and exhaust analyzer and 2 or 3 makes of PLC's we have. I had to buy 3 brands before I got one that worked though.
But there are 2 devices I occasionally hook up to that even it won't com with, and I had to get a PCMIA card that has a DB9 adapter. I wish they had just left DB9 ports on laptops Good Luck Jim
Tim Smith |
Making the slightest amount of progress. I did locate and download from holley the version 3 pro software. Managed to get it to installed and run on the vista laptop, had to set both the installer and the program itself to xp compatibility mode & run as admin to do that. I found this weird lil peice of cable with a dead end on it's connector, took the dead end off, found 2 terminals with nothing on them... found one had 12 volts. Well the wiring diagram showed the power lead should have a fuse, and this thing sure looked like it could hold one, so I stuck one in there. Now when I power up IGN I'm getting power on the injector power and fuel pump leads!! Fuel pump power quits after a 4 sec prime just like it should! It's kinda wierd tho. Voltage builds and falls on those 2 wires VERY slowly. Hoping it's just because the low resistence load of the relay coils isn't there. And I still can't talk to the damned thing. I'm about ready to drag it into the house and plug it into a desktop machine with a real serial port and running xp. That's quite a production tho.. The ECU, the harness, and the battery charger and dead lawn tracter battery I'm using as a power source...lol. Think I'll give it up for the night. Going racing tomorrow!!!
So yesterday I brought it to work. I made up an adapter cable so I could plug it into a pc for power, and had it up and talking both with a straight serial cable and my usb cable to an xp desktop.
Now all I gotta do is figure out how to make it work with my vista laptop. At least I know for sure that the unit is ok.
Your problems could be that your lab top runs vista.
My friend just bought a new engine scanner and the instructions say it wont work with vista. Rich
AFR Heads W/ Jesel valve train http://www.fquick.com/Rich-Allen 67 RS / SS http://eastbayerectors.com/camaro.html |
I talked to DougF (on chevytalk) and he said he has tested (semi-successfully) with vista.
He also said certain things, such as the datalogger, didn't work. Without the datalogger, I'm not sure I'm interested, unfortunately, there's no way to "un-vista" without wiping the drive.
Your USB to Serial adapter may need to be a Null adapter?
#11
That's what I was thinking, but couldn't think of the name....senior moment/month.
Give a man a rescue dog for the health of his soul. My 68 Camaro http://www.flickr.com/photos/everettwn68 |
#12
I considered that possibility, but it did work fine from the XP machine.
Tonight I'll bring a power supply home and mess with it some more. Not in a big hurry to get this going, it's summer and I like my vert to be ready to roll at all times, but I do want to get things collected and planned so the eventual install is trouble free, and that will include putting together some base maps with the proper specs for the autometer wideband, timing curve, stuff like that. Also need to start collecting fuel line stuff, and make a plate to mount the pump and filters on, and collect some fuel lines for the underhood connections, and figure out where to put the c950 box. Thinking of in the console, wonder if it will fit under the gauges?
#13
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost |
#14
Everything I have seen says it works with Windows 95 and 98. I just gort Vista at the office and constantly deal with lockups and other wierd crap. The older program may work right with Vista yet.
#15
I've talked to it ok from XP. I bought a new cable that was recommended on another site, from DIYEFI.com I think, and brought home a pwoer supply so I could fire it up, but been so busy I haven;t got to it yet, system is still laid out and lonely on the workbench.
Similar Threads
| Post your EFI Conversion here | Rodder | EFI in your modern Classic | 14 | May 26th, 07 08:07 PM |
| 67 console gauges conversion | Eighttrakz | Electrical & Wiring | 3 | Mar 7th, 06 09:12 PM |
| 67 Powerglide column to floor shift conversion | JeffLit | Transmission & Driveline | 2 | Nov 14th, 05 06:00 AM |
| MAF EFI Conversion From Quality Roadsters | squid | Engine | 5 | Jul 12th, 05 09:55 AM |
