Turbo 400 identification - Team Camaro Tech
Old Jun 25th, 07, 07:11 AM
Stewie Stewie is offline
Default Turbo 400 identification
When I bought my car the previous owner told me it was a turbo 400. I was wondering if there is any way of telling exactly what trans I have. Is there a number or a specific type of pan for this transmission.
The reason I would like to know is that I do not have a linkage for the passing gear, and I am tryiing to find out which one I need.
Another questions is there an aftermarket one size fits all solution.
Thanks in advance.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
I currently own a 1968 Camaro Coupe 327 275 Hp
http://i15.photobucket.com/albums/a3...z/P5170084.jpg
Old Jun 25th, 07, 07:25 AM
Strick Strick is offline
Strick
Default Re: Turbo 400 identification
The turbo 350 pan is basically square the turbo 400 pan's shape looks like a fat state of Nevada.
Strick
'67 'Vert (408" SBC), V-Rod, Street Glide, and too many other motorcycles to list.
Old Jun 25th, 07, 08:51 AM
I went and had a good look at her and I am pretty sure it is a 400. I also checked the kickdown switch and it is in place. All that seems to be missing is the linkage(lever) that pushes the plunger when the gas pedal is floored.
Does anyone know what part I am looking for. It is a quadrajet carb, and the switch has about a 2 inch long plunger. I will take a picture and maybe someone can tell me what I need to do to get it working.
Here are two
http://i15.photobucket.com/albums/a392/Stewz/carb.jpg
http://i15.photobucket.com/albums/a3...wz/linkage.jpg
I am not sure if this set up is even for this car.
Any help is much appreciated.
Old Jun 25th, 07, 11:16 AM
TJS69 TJS69 is offline
Tom
Talking Re: Turbo 400 identification
You need to fab. up a bracket on your throttle rod, that will contact the switch plunger, when you stomp on it. TH-400's didn't come from the factory in a '68 behind a 327 or any smallblock for that matter. A TH-350 has a kickdown cable and the TH-400 has a switch, like you have.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Jun 25th, 07, 03:45 PM
Yes, I thought as much. I think the last owner had designs on a Big block but ran out of cash. He had the big block springs in it. Is there any other after maket type of switch that I could use. It is not a big deal but I would like to have it working if I could.
Old Jun 25th, 07, 10:14 PM
Strick
I have used the lokar kickdown on classics in the past for the TH400. I works greats, and looks even better. I think summit sells them for around $60. It is a 30-40 minute install (including wiring) very easy!
Strick
Old Jun 26th, 07, 08:45 AM
Hey thanks Strick. I looked at the kit on the Summit web site. Where does the switch bracket attach? I will be in the US next week, and I will try to pick one up.
Old Jun 26th, 07, 11:14 PM
Strick
It uses two pan bolts, if I remember correctly. It fits snug to the transmission and then braided line to the carb.
Strick
Similar Threads
big block with 2.73 gears and 400 turbo? 68zz502fi Transmission & Driveline 18 Apr 10th, 07 08:03 PM
Turbo 400 or M21 Munice. Final Vote-New 396 BB-Photos! 68CamaroJoe Transmission & Driveline 17 Apr 8th, 07 06:13 PM
Turbo 400 not moving car cool rocking daddy Transmission & Driveline 3 Aug 14th, 06 01:32 PM
400 turbo trans cross member Illinois69SS Transmission & Driveline 3 Dec 27th, 05 04:55 AM
is it tru that a turbo 400 takes power from motor??? camaro79tx Engine 18 Nov 17th, 00 06:06 PM
