What is this milky fluid in my radiator - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Jun 26th, 07, 02:56 PM
shockers69 shockers69 is offline
Default What is this milky fluid in my radiator
I just purchased a 69 with a 383 small block, manual transmission i got it home and when i looked in the radiator i freaked out.I drained a little out today in a glass mason jar it looked just like milk, white and thick .My first thought was stop leak. I drained and flushed the most of it out and filled with tap water thinking where ever it was leaking it would show up.The engine oil looks good.I took a sample of milky fluid to my local radiator shop he said he was sure it was anti-corosion/lubricant i checked it and it would not float any balls on my anti freezer tester so i believe and also praying that i do not have a problem.Have you ever heard of anybody running this.The guy that had the 69 came from a family of drag racers.Maybe racers run this stuff.What do you think?
Old Jun 27th, 07, 05:33 AM
67CamaroRS/SS 67CamaroRS/SS is offline
Charlie
Default Re: What is this milky fluid in my radiator
The only time I have ever seen a milky substance in the antifreeze is when a head gasket blows and you get oil and antifreeze mixing. Take a compression check of all cylinders. I bet you'll see 1 or 2 cylinders that are low. Hope this helps. Keep me posted.
Charlie Knudsen 67 Camaro RS/SS 350 TKO 600, 4.10's, AFR 195 Street Heads, Comp 270H, Rhoads Lifters, Crane Ignition, Pertronix Dizzy, Performer RPM Q-Jet, Heavily Modified Q-Jet, Hooker Comp Headers, MagnaFlow 2 1/2", 144 Decibles(Alpine CDA-7998 Head Unit, RF X7 and RF 750X Amps, MB Quart Mid's & High's, Kicker L7 12" Solo Barics)
Old Jun 27th, 07, 05:36 AM
onovakind67 onovakind67 is offline
Soluble oil from products like Bar's Leaks will look milky in your radiator.
Old Jun 27th, 07, 09:01 AM
wiskeesour's Avatar
wiskeesour wiskeesour is offline
Harley
Talking Re: What is this milky fluid in my radiator
Ditto. ESP if theres not enuff water in with it.
AE2(AW) Harley Moody, USNavy
"Master-at-Arms" for the CDWJB!!
November 26th, 2008 was my last day to serve my country as a member of the World's Greatest Navy.
Thanks Chief.
Old Jun 27th, 07, 09:32 AM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
If the bars leak or other like product is not it your not going to like my possibilty.
There are oil passages that are near water jackets and if the block is cracked to one oil will get to the water. Since the oil pressure is higher than the water pressure water may never get to the oil. Been a very long time since I have seen a problem like this.
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
Old Jun 27th, 07, 10:14 AM
Charlie
If it's not a cracked head it may just be a blown head gasket. That's why I suggested you take a compression test. If there is a problem in that area you will see it with the test.
Old Jun 27th, 07, 05:07 PM
schifrin schifrin is offline
Jeff
Ten-four on that 67CamaroRS/SS simply having the car jacked up (rear higher) blew out and killed my engine back in the early 70's pressure on head gasket and my radiator was all muddied up with goo--foamy like a milkshake. Big lesson.
Old Jun 27th, 07, 09:56 PM
eriksbird eriksbird is offline
Erik
water pump lube and anti rust conditioner is white and looks like milk wont hurt a thing if you drained the water and it went away I would not worry about it
Similar Threads
Radiator fluid leak Cossack Warrior Engine 10 Mar 14th, 06 04:38 AM
Radiator Fluid ??? desertdawg39 Heating & Cooling 6 Feb 27th, 06 12:52 AM
Brake Bleeding the right way WillS Brakes, Suspension & Steering 0 Feb 14th, 05 03:45 PM
Radiator Fluid at Bottom Edge of Intake Manifold SFCamaro Engine 4 Aug 13th, 04 01:03 PM
PepBoys3row radiator doesn't fit '68straight6/fiberglass parts a mistake?/bad gage? richcamaro68 Heating & Cooling 2 Jul 27th, 04 03:15 PM
