Pro Touring Todays performance with classic style
Old Jul 1st, 07, 02:33 PM
Kevinator Kevinator is offline
Default 9 inch rear with with 18x12
Want to know what with 9 inch on 69 camaro with DSE mini tub 3 inch kit and 335 tires. I want housing to be short as possible to give rim less backspaceing.(4.75 or 5 inch). I need to cut down housing so i can order moser axles. Any help is app. Thanks,Kevin
Old Jul 2nd, 07, 12:38 PM
marty69212 marty69212 is offline
Default Re: 9 inch rear with with 18x12
you need your wheels and choice brakes before you go narrowing your rear axle... set them in place and measure .. most camaros , though the same car, will come out with different measurements!!! even some ive heard come out with an offset pinion after measurung and mocking !!!
Old Jul 2nd, 07, 01:40 PM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Mock it up and measure. Don't rely on somebody else's measurements.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Old Jul 2nd, 07, 06:00 PM
ProdigyCustoms ProdigyCustoms is offline
Frank
We do a 55" rear with a 6" back space on a 12" rim for 335s. If you have balls you could go 53" on the rear and a 5" backspace. Usually they are dead on or need a 1/4" spacer to move them out. If your not going to mock up and measure, you are much better to error to much backspace.
Also, when you are ready for axles let me know, we will set you up with Moser's
Frank Serafine
Prodigy Customs
Pro Touring Muscle Car Specialist
FREE PRO TOURING TECH and PROJECT PLANNING for Forum Members
Weekdays 8AM TO 10PM EASTERN TIME
FOUR ZERO SEVEN 832 1752
GP SuperStore
Group Purchase Discount Auto Parts
Old Jul 3rd, 07, 08:59 AM
Thanks Frank, I have used GP store before and think you and Lisa are doing a wonderful thing for the people that has car bug in their blood. I have a 52 1/2'' 9 inch housing. I just want about 4.75 or 5'' BS for a little dish look, but not to much. Thanks,Kevin
Old Jul 3rd, 07, 07:13 PM
Frank
I am talking about 55" wheel flange to flange, not housing width. You should add 5 inches to your assembled housing, so that is a 57 1/2" rear, which would make for a 7 1/4" backspace on 12", and about a 4" to 4 1/4" lip on the outside.
And thanks for the kind words.
Frank Serafine
Prodigy Customs
GP SuperStore
Similar Threads
8 inch rear view mirror 36j1967 What's it worth? 4 Nov 28th, 06 01:51 PM
Ford 9" Rear? BERRY251 Transmission & Driveline 15 Oct 11th, 06 05:28 PM
9 inch rear end brakes camarokid24 Brakes, Suspension & Steering 13 Jul 7th, 06 05:39 PM
Rear of hood too high. Brackneyc Body Shop 10 Apr 28th, 06 07:20 PM
10 inch wide rear wheels the mechanic Wheels & Tires 4 May 10th, 01 04:38 PM
