| Team Camaro Tech Current Topic: Holley TBI on my ZZ4 - ignition question | ||
| EFI in your modern Classic EFI conversions in FirstGen Camaros |
Jegs will be delivering my Holley Commander TBI on monday - really looking forward to this project!
Does anyone know how my ignition system will connect? I have a non-computer controlled HEI distributor and a MSD 6AL ignition. I'm concerned that i may need to order an additional wiring harness adaptor or something else that i'll be missing when i go to install this. Thanks
Jeff Supinski '69 SS - Hugger orange, white stripes, Ivory interior. ZZ4,M-20,3.42's '07 GMC Sierra Crew Cab '68 F-250 |
I just bought a 69 w/ a Holley Commander 950 TBI set up on a 383 SB.The person that put it in had to get a small cap HEI and a wiring adapter from Holley.I think you can use what you got but you will not have timing control.
Jeff, the c950 needs an rpm signal to function, which it can get from the tach terminal on your HEI. I have run a C950 this way, and it certainly functioned just fine.
The c950 has the capability of controlling the cars ignition timing. To use that you need a distributor intended for computer control. A computer control distributor will not have a mechanical or vacuum advance system, and will have a different type of module, with more than the 3 wires yours has.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI 04 Silverado SS The Black Beast 93 Polo Green Corvette http://www.Jimragtop.com Jim's NEW Blog! Jim Cam |
Similar Threads
| holley carb question | Stainless dog | Engine | 3 | May 7th, 07 05:53 PM |
| Holley power valve question??? | dubs68camaro | Engine | 1 | May 7th, 07 12:14 PM |
| Holley metering block I.D. question | dubs68camaro | Engine | 2 | May 5th, 07 10:48 PM |
| 4053 dz holley question???? | 69z28boy | Performance | 11 | Nov 12th, 06 04:31 PM |
| Question about the MSD 6al Ignition Control Box | garfield | Bench Racing | 2 | Jul 27th, 04 04:04 AM |
