| Team Camaro Tech Current Topic: AHHH, more stripped block threads!! | ||
| Engine General Engine Discussion. |
I have never had this many problems with stripping the deck threads in my whole life of building engines. My block has been decked .010 below zero, could this be the reason? I soon will have ALL of the deck holes heli coiled! Has anyone else ever had this problem? I'm using bolts also. I would have bought studs if I knew this was gonna happen.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/8-7.6sec@88mph,1/4-12.1@110mph,Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall 383 IS SOLD! Building a 489BBC http://s90.photobucket.com/albums/k264/pnewell44/ |
| Sponsored Links | ||
Advertisement | ||
400 block? This is prolly best time to insert all helicoils, install studs and seal them well,,,, with Indian Head Shellac compound.
Don TC # 349 Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E http://s102.photobucket.com/albums/m...t=115_1577.jpg |
nope, 350 block. yea I'm probably gonna heli coil all of them so I dont have to keep pulling off the head.
How is the accuracy of your torque wrench b/c if it is off by say 25 pounds, you may just be twisting the threads out of the block past stock torque and not know it!!
pdq67 |
Consider that you have prolly taken off some .035 off deck of that block as normal stock deck is about .025. You prolly dont have any champher in the bolt hole area, I would do this before you set coil in or set coil deep. Dont want it right at the edge of deck.
I have only seen one other block do this back in the early 90's it was a Mexican casting.
good idea. thanks
Use studs for one.
They don't turn in the the deck's threads while torquing up like bolts do. Friction in the threads is practically zero when using studs.
Nov 68 Van Nuys. 327 floor-shift-auto, Frost Green and not much else when new. http://img233.imageshack.us/img233/3...sychedelic.jpg http://www.usmuscle.com.au/Forum/showthread.php?t=2840 |
| Sponsored Links | |
Advertisement | |
Similar Threads
| Small Block or Big Block | PDW HOTRODS | Performance | 25 | Dec 19th, 05 06:21 PM |
| Aluminum Block Info | zl1num12 | Engine | 6 | Aug 28th, 03 08:09 AM |
| BB frame mounts further forward than small block | camcojb | Engine | 24 | Jun 28th, 03 09:23 AM |
| stripped threads on intake | 94Harley | Engine | 3 | May 5th, 03 09:29 AM |
| HELP - Stripped threads | ramcda | Engine | 3 | Dec 13th, 02 03:01 AM |
