1960's Sound deading spray? - Team Camaro Tech
Body Shop Paint & Body Forum
Old Jul 16th, 07, 05:53 AM
Rich-Allen Rich-Allen is offline
Default 1960's Sound deading spray?
I have this thick spray crap inside my rear fenders and I want to know if this was from the factory.
This stuff could be as thick as 1/2" in some places. I'm starting to think the clown who built this car sprayed this stuff to make it look factory.
It does look old but anything could be made to look old.
Rich
AFR Heads W/ Jesel valve train
http://www.fquick.com/Rich-Allen
67 RS / SS
http://eastbayerectors.com/camaro.html
Old Jul 16th, 07, 09:34 AM
Vintage 68's Avatar
John
Thumbs up Re: 1960's Sound deading spray?
I'm going to guess you have a Van Nuys/LA built car then ...
Yes, the factory did spray the rear fender wells and certain areas in the trans tunnel and front area of floor pan with undercoating/sealer/sound-deadeners during the body assembly right after the major paint process steps. These areas are part of the initial Fisher/GMAD body assembly process and I don't know of a published source of the information outlining this process - maybe JohnZ or someone can chime-in with some documantation.
The areas in the front wheel house to be sprayed during final assembly are outlined in the AIM (UPC 11-13, A4 in 1967 AIM) for each year - BUT, the actual areas sprayed by each plant varied quite a bit.
The Norwood built cars I've worked on seem to follow the AIM guidelines for the front wheel hose coating pretty close and also seem to have more sprayed material in the rear wells, the tunnel area and the front of the floor pan.
I have observed numerous cars built at Van Nuys and, the for most part, there was little if any material sprayed in the front wheel house areas.
The amount of material in the trans tunnel and on the front floor pan area also varied greatly. The Van Nuys car seem to have less material under the rear of the car - this may just be a true "good day/bad day" thingy.
I believe someone posted a pretty good diagram of the underside of their car showing where the coatings were as they stripped them. I thought I had saved a copy of the photo, but I can't find it - try a search of "undercoating' and see if the past thread comes up.
Hope this helps some.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jul 16th, 07, 09:43 AM
Default Re: 1960's Sound deading spray?
Hi John, thanks for the reply,
You can only see a little portion of the rear fender in this photo but it does have some of this coating on it.
Further up the coating is thicker. The guy who blasted this stuff must have been stoned. I can see big thick runs where too much coating was applied.
I would estimate the thickness to be 1/2" at it's thickest point.
The front fenders do have a little coating but nothing like the rear.
The trans tunnel had nothing.
I want to remove this crap and check the condition of the metal beneath.
Any suggestion how to remove it? I tried to get a little piece off yesterday and it took a hammer and screw driver to chip a piece loose.
67 RS / SS
Old Jul 16th, 07, 09:54 AM
Vintage 68's Avatar
John
The best way I know of is a 'heat-gun' and some scrapers
It takes some time, but it's a much cleaner way than trying to desolve the stuff with solvents - doing it this way once just left some nasty stains in my driveway
I use an industrial type heat gun and those toss-away plastic scrapers you can get at OSH/hardware stores for a 'buck' or so. The plastic scrapers don't hold up all that well, but they don't scrach the $hee-it out of the metal like the normal metal scrapers did either.
I then use a rag and most normal cleaner solvents to remove the final little bits of the coatings and clean the metal.
1968 Convertible
Some trucks
Old Jul 16th, 07, 10:13 AM
Thanks John, JimM also recommended using a heat gun. I just put one on will call at Graingers.
I should get some time later this week to start removing it.
Rich
67 RS / SS
Old Jul 16th, 07, 10:21 AM
Vintage 68's Avatar
John
Talking Re: 1960's Sound deading spray?
... JimM also recommended using a heat gun.
Rich
That JimM is a smart guy
Have fun - oh, wear old clothes
btw - I also use a Norton 'RapidSTRIP' (#04015) stripping wheel to remove small amounts left and clean the metal without damaging it. These wheels mount to you standard 5/8" grinder mandrel threads and don't need an adapter.
1968 Convertible
Some trucks
Old Jul 16th, 07, 11:54 AM
Rocketrod Rocketrod is offline
Use Mr. Muscle oven cleaner and a pressure washer if possible. I personally found it much more effective than the heat gun method.
Rod
69 Camaro with LS2/4l70e
Smoothing firewall and Upper dash panel replacement
Old Jul 16th, 07, 02:04 PM
Unreal Unreal is offline
Gary
I chipped mine out with a large dull screwdriver blade (removed the handle) and a hammer. The dull screwdriver did not scratch the steel, and the pieces came out as small chips rather than a hot goowie mess. Took a couple of hours per wheelwell, though
Similar Threads
Knocking sound after warm up rickmack Troubleshooting 29 Jan 26th, 13 11:21 AM
Lizard Skin Sound Deadening Material? Texas68 Interiors 5 Jan 26th, 07 07:46 PM
Spray Gun World 69Mike Body Shop 10 Feb 14th, 06 05:13 PM
v8 sound 1bad69+70 Performance 4 Sep 10th, 05 12:33 AM
Swisch sound.... MagnusRS68 Engine 11 Feb 24th, 04 05:09 AM
