Ladder bars vs. Traction bars - Team Camaro Tech
Thread Tools Display Modes
Old Jul 16th, 07, 08:10 AM
Lifeboatdan Lifeboatdan is offline
Dan
Default Ladder bars vs. Traction bars
Anyone have any opinion as to which on is better? Ladder bars (Lakewood) or traction bars? I am trying to decide which ones to put on my 70 Camaro 383 stroker (475hp).
Thanks Dan
Old Jul 16th, 07, 08:19 AM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Default Re: Ladder bars vs. Traction bars
Depending on the type of ladder bars, traction bars at least allow some degree of body roll. Most ladder bars don't, which can be dangerous on the street.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Old Jul 16th, 07, 08:49 AM
JimM JimM is offline
Jim
In addition, unless you use "floating" spring perches, ladder bars bind up a leaf spring suspension pretty bacly.
Old Jul 18th, 07, 06:13 AM
Dan
Thanks Guys, I will stick with slap bars.
Old Jul 18th, 07, 07:10 AM
craggar1 craggar1 is offline
Craig
I'd go with Cal Tracs or Slide A Links with your combo.
69Z28 427sb
74 Vega 355sb
Old Jul 18th, 07, 08:29 AM
mkpatrick mkpatrick is offline
Mike
I'm having pretty good luck with the CE-2101's I put on my 67. Not sure which one would work for you but these have a J-bolt and hit the snubber right on the spring eye.
My suspension now reacts very well. There is a marked difference between these and my Lakewoods.
Note:
CE's customer service was very bad. The J-bolts they supply sucked. They didn't fit well and it was hard to get them on. I took the J-bolts to a local place here and had them make me some that fit better. Then the 2101's dropped right in.
You may have to use wedges to space the snubber to the gap you prefer. I used wedges and I used Energy Suspension snubbers, they are much shorter than the CE/Lakewood ones.
Anyway, just what I've eperienced lately.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Ladder bars vs. Traction bars
Location
Location
First Name
Human Verification
Similar Threads
Leaf spring traction bars 540 RAT Performance 33 May 31st, 07 07:58 PM
Traction bars bb489 Performance 5 May 7th, 06 04:33 PM
removing traction bars and replacing leaf springs 67SSragtop Brakes, Suspension & Steering 6 Jul 5th, 05 06:49 AM
removing traction bars sudo1a67ss350 Brakes, Suspension & Steering 4 Mar 25th, 03 07:35 AM
Questions for guys running traction bars on the street... BC Brakes, Suspension & Steering 32 May 19th, 02 06:03 PM
