| Team Camaro Tech Current Topic: SBC Casting #'s VIN | ||
| Tag Team De-coding tags and numbers. |
I'm trying to decode the Numbers on my Blocks So far. This car is a mut so even though i have a 68 Camaro Standard V8 build in Norwood[Decoded from the VIN of the car] the drivetrain may not be from it.
I was told i'm a 350, and i know i'm a 2 bolt. I did tear down part of the engine to get these numbers below. How can i tell for sure i'm a 350? Under the assumption i am below is what i found with my #'s given a 350. Block: <using nastyz28.com> Casting # [Dr. side rear on flange]: 3970010 1969to79, 350, 185 to 370HP, 2 bolt, application: car truck vette I couldn't read the date code on the rear of the engine [i'll give it another try tonight]. Vin #'s [on the front of engine on the machined pad]: C6U146960 V0107TYA <Using NastyZ28.com> V0107TYA: Flint Engine Jan 7 Suffix Date CID Application VIN HP BBLS Body TYA 1975 350 car & bus V LF5 145 2 c-10 & 1500 TYA 1978 350 van & bus L LS9 165 4 c-20 to 3500 what does the VIN mean? V LF5? L LS9? What does BBLS mean? I have no idea how to decode C6U146960 - Any ideas? <using jimsperformace.com/cranks.html> Crankshaft: Casting # 3932442 267/305/350 Cast Crank with Medium Journal, 3" Stroke, 2 piece main seal Camshaft: on the face of the cam that points out of the front of the block: Comp Cam 270 H Transmission: <using chevellestuff.com> Case Tag: I know its a TH-400 from the pan so since the tag only has stamped markings: 260 : 260th day from January 1, 1969 70-CA-12122 1970 CA - 350,396,400,402 (145,160,170,240,255,265hp) 2bbl, Chevrolet, Monte Carlo, Tranny Serial Number 12122. Rear Tailhousing: 8628121 No idea how to decode that Thanks for any and all help!!!
1968 Camaro; 350/th-400 Last edited by VintageAgain; Jul 27th, 07 at 10:51 AM. |
| Sponsored Links | ||
Advertisement | ||
Someone else will tell you exactly what your engine is out of etc. The crank is listed in Mortec. com as a 267, 305, or 350 crank. 3.48" stoke
http://www.mortec.com/cranks.htm
1968 Z28 British Green, all original except CE 302 engine. Have original owners booklet and protect-o-plate. |
Thanks,
That's a different stroke value then the site i went to - How do i know which site is correct? I found the Cam Value its 270H from Comp Cam. But i can't seem to find any more info on it. Any ideas? Or things i should look for to help get more information. Thanks
1968 Camaro; 350/th-400 |
http://www.compperformancegroupstore.../merchant.mvc?
Mortec is usually pretty close. The 3" stoke would be a 302 or 283 crank.
JohnZ CRG '69 Z/28 Fathom Green |
I would love!!! to know how you decoded that. Did you have a chart or a website or something? I'm trying to keep a log of all the #'s what they mean and the place of reference where the info was taken from.
6 = Model year 1976 (that block was only used from '69-'80) U = Lordstown plant identifier
awesome, thanks!
| Sponsored Links | |
Advertisement | |
