Pro Touring Todays performance with classic style
Old Aug 3rd, 07, 08:08 AM
Lance-w Lance-w is offline
Gold Member
Default Subframe cutting to run the big tires :D
I have to cut the subframe to run the tires (275-40r17) I want. So yesterday I played hookie and started cutting. The pictures will tell the story far better than I can.
This is the inside of the drivers side in front of the tire. You can see there are two levels to the "floor" of the frame here. While I'm here I'm also going to re-inforce the floor to strengthen where the swaybar mounts.
The pattern I made to raise the floor to a level area. My daughter thought the beer box material I used for the pattern with the big gulp picture on it was hilarious
The filler piece
The 11 ga re-inforcement.
This part is going nowhere
The curved part of the patch (11 GA)
This sway bar is going to have to change huh !!!!!!!!! Can these things be heated and bent without damaging them?
Old Aug 3rd, 07, 08:09 AM
Gold Member
Default Re: Subframe cutting to run the big tires :D
I guess you can only put ten pictures in at once???????????
The steering box location was by far the one I was worried about the most. It turned out to be no big deal......
What it looks like inside there....
Patch welded
A different angle
And the payoff for all this effort
Now all I have to do is the other side of the car
Lance
Old Aug 3rd, 07, 08:15 AM
Rhino Rhino is offline
Ryan
Looks like great fab work! Congrats.
How much would you expect this to reduce the lateral rigidity of the frame? I realize it's still boxed, but it looks like you're removing a significant amount of material.
Old Aug 7th, 07, 07:28 PM
davidpozzi davidpozzi is offline
David Pozzi
Nice job, thanks for posting the pics!
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
Old Aug 8th, 07, 08:20 AM
Gold Member
Hmmm I thought about that before I did it. Seriously (not trying to be a smart alec with that statement at all)
I think that the way it's done with the curved sections that it's not that big of a loss. The frame is two barely welded together stamped C shapes. The outer one is quite a bit thicker that the inner one. The outer one carries more load as a result, unfortunately that's where I had to cut. I also have added pieces to the top and bottom surfaces where the cuts are to carry the thicker portion of the frame to the inner face. I'll post pictures of that this weekend after I finish it (I hope). I still have to put the LS1 in and make the cut for the A/C compressor. After that it'll be off to the sand blaster and then back into the garage to have the complete seam between the inner and outer portion of the frame to be welded completely from end to end (have you ever really looked carefully at the factory welds ) As a side note does anybody have ideas on what they've done to their factory frames to stiffen them? I have some ideas but I'm looking for ideas fropm what other people have done also.......
Lance
Old Aug 8th, 07, 08:22 AM
Gold Member
David
Your welcome
I need a bigger personal showroom though
Old Sep 6th, 07, 08:29 AM
Ryan
Did you ever figure out what you're doing with your sway bar? I'm curious to see the outcome of all this.
Old Sep 6th, 07, 08:35 AM
Gold Member
Nope I haven't figured that out yet. Seems there's quite a few opinions whether you can heat them and bend them. Some people say yes and others say no. I actually thought about cutting it in the middle too and just joining it with a sleeve. Have to be quite a hefty sleeve though. ATS also sells a sway bar that is a different style that might work better but it's gonna take a bite in the budget I'm sure
The Subframe is at the sandblasters today so when it gets home today I'll weld all the seams completely and remove all that junky factory weld globs. Then it'll get primed and painted and put away till I get the body shell painted.
Old Sep 13th, 07, 05:23 PM
V-12-Camaro V-12-Camaro is offline
Tech Team
I'll 2nd the nice fab work. Really good on the welding. The after-grinding smoothness is flawless. Most people would have left the welds exposed. It scores more points for cleanliness.
Nice work on recessing the bolt, and a grade #8 at that.
If you address all the little details on the whole car, like you did on the frame, It'll be a sharp ride. Keep the pics coming as work progresses.
I always wondered what the inside of those frames looked like.
Old Sep 14th, 07, 10:13 AM
Mark SC&C Mark SC&C is offline
Tech Team
Real clean fab work! Nice job.
A little trick for things like this where you get a big change in cross section like at the back of the subframe. On something like that I like to add 2 pieces of 1/8" or even 3/16" plate horizontally against the back side of the cut. They should extend well into the areas that are uncut on both ends. Looking into the cutout area they would be viewed edge on and equally spaced vertically. Trim the outter edges to fit snug against the contour of the outter filler panel. I weld them inside the uncut ends and all along the back side then mark and drill the outter filler piece with a row of holes large enough to plug weld it to them. When you`re all done grind and smooth the plug welds. This ads a LOT of lateral rigidity to the part as it`s very hard to bend steel plates edge ways. Mark SC&C
--Savitske Classic & Custom--
Pro-Touring,Hot Rods,Muscle Cars
-Cutting Edge Suspension Products-
SPC,Varishock,Spohn,Baer,Howe,ATS
Chassisworks,Lee Power Steering,Currie
www.SCandC.com NEW!tech@scandc.com
(610) 346-8805
Old Sep 18th, 07, 02:45 AM
sweetblue69 sweetblue69 is offline
Daniel
Swaybars are made with spring steel, I'd put money down that if you cut and weld in the center then thats going to break unless you go ridiculously big. Also, you can't just shorten it, the ends won't reach far enough and will rub on the springs. You can't fix this by using longer end links, they just don't fit on lowered cars. That looks like an addco bar like mine, does it actually hit the tire? With my '69 the offset is pretty wide and I only have issues with the fender, simple rolling fixes that. So far I haven't been able to get the front end to walk out on me, just the back goes first under braking, neutral cornering or corner exits. currently 245/50/17 front, 255/45/18 rear. As soon as the rubber goes in the back I'll put in some 275/40's back and keep the 245 front size. That should make the handling more neutral. I'm sure Pozzi has some insight about this hehe.
Old Sep 18th, 07, 08:01 AM
Gold Member
I did double up the floors and roof of the cut areas but I didn't think to run intermediate gussets....oh well guess I'll do that on the next one
Great input, thank you. Your right about not being able to just move the ends inboard. They need to move inboard and then be bent back out to match the mounting point. Basically the angle on that outboard end needs to change to sneak in behind the tire. The tire definately hits the bar so I'm going to have to do something I just haven't decidedd what yet. I painted the sub frame yesterday so it's effectively done till I get the body painted and start putting stuff back together and come up against the sway bar problem again......
Excuse the mess but I need a bigger garage (but then don't we all )
Lance
Old Sep 18th, 07, 08:34 AM
Ryan
That turned out Excellent! Congrats on a job well done.
On a related note... do you have any more pics of your notch to clear the A/C compressor? I'm looking to do something very similar.
Old Sep 20th, 07, 02:35 PM
Gold Member
This is what I have here at work. I'll try to remember to take some better ones tonight.
Old Sep 21st, 07, 01:21 PM
Ryan
I didn't think I'd ever have to say this... but your subframe is too shiny! it's hard to make out detail.
What is the front/aft hole shown in the notch area? Is this hole stock or added for A/C lines?
