| Team Camaro Tech Current Topic: LS1 out of a Trans AM?? | ||
| EFI in your modern Classic EFI conversions in FirstGen Camaros |
Is the LS1 out of a Trans AM the same as one out of a Camaro or Corvette?
Are all the parts interchangable?? Thanks |
most everthing but the throttle body (vette is drive by wire)
Don't forget that the Vette has different accessory brackets. (right?, or is that just LS2?)
I guess my question was not if the parts are interchangable but are aftermarket parts the same..
Should I bother looking at one for my 69 or am I better off with a Camaro or Vette? THanks |
www.ls1tech.com
I thought camaro & firebird are same. Vette will have acc differences, oil pan maybe too? |
F-body accessory drives are the same across brands. Corvette accessory drive is different, but shorter than F-body and has the alternator in a more traditional location.
Carl's Camaro |
The aftermarket parts such as heads, cam, intake, headers, etc interchange among all of the GenIII smallblocks (4.8, 5.3, 5.7, 6.0). The only gotcha I can think of is for truck people, since the F-body/Vette style intake manifolds won't clear the belt tensioner on the truck accessory brackets. The harmonic balancer (with integral crank pulley) needs to match the accessory brackets you use. The F-body LS1's seem to be a lot more popular for swaps than Vette LS1's. I think that's because they're more plentiful, and because people are buying the engine+trans together--the Vette trans is mounted at the axle which makes it undesirable for most swaps (unless you are back-halfing the car with the Vette IRS).
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost |
