rear sway bar? - Team Camaro Tech
Old Aug 9th, 07, 03:46 AM
kgmunro kgmunro is offline
Ken
Default rear sway bar?
can you get a rear sway bar for a 69 camaro?If so what donor cars can I get one from?My 69 has new rear springs but seems to roll a bit more than I would like going around the corners.
Old Aug 9th, 07, 04:55 AM
parkbrau's Avatar
parkbrau parkbrau is online now
John
Default Re: rear sway bar?
Not sure about donors, but you can buy them from Parts suppliers such as Ground up or classics. About $ 100.00
John, 69 Base Coupe, Rallye Green
Remember, Its not WWIII until France surrenders!
Old Aug 9th, 07, 09:49 AM
davidpozzi davidpozzi is offline
David Pozzi
Get a matched pair of front and rear bars or the handling will be unbalanced.
The usual setup is a 1" solid front bar. The rear bar size varies depending on it's shape and arm length/mfr.
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Aug 9th, 07, 11:56 PM
BlackoutSteve BlackoutSteve is offline
Steve
Penske used a front sway bar turned up-side-down using custom made brackets.
It's in the book "Camaro. Untold Secrets"..
Sounds like a good idea if you can fab you own brackets.
Nov 68 Van Nuys. 327 floor-shift-auto, Frost Green and not much else when new.
http://img233.imageshack.us/img233/3...sychedelic.jpg
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
