EFI in your modern Classic EFI conversions in FirstGen Camaros
Old Aug 9th, 07, 08:25 PM
camaro-69ss camaro-69ss is offline
Jeff
Default The Commander is in, runs terrible
Fisnished up my install tonight, and I've got some weird things going on. First, I'm having a real hard time getting it to idle smoothly. It fluctuates all over.... very rich, then very lean, back and forth. But here's the real kicker - I can no longer shut my engine off with the key!!! AND it runs WAY better with the key in the off position!!! When wiring up the Holley harness, I took the power right from the battery and the switched source from the same lead i was switching my MSD 6AL with. It's hot when the key is on and cranking, off when the key is off. But after it's started the only way I can shut it down is by pulling the main wiring plug out of the ECU. I shut it down and retested the switched source and it goes on and off with the key. WHAT THE???? Any ideas on that one? So anyway, I start it and it runs crappy, then I turn the key off and it smooths out the idle and leans it down. Turn the key on and it runs rough and gets really rich. Or maybe I have those terms backwards..... with the key on when it runs terrible, the A/F ratio is 10. When i turn the key off and it smooths out the A/F ratio goes to 18.
I know I have a long way to go with the tuning, but I first have to figure out this key thing - there is something very obvious happening with the key on that the system doesn't like!
Jeff Supinski
'69 SS - Hugger orange, white stripes, Ivory interior. ZZ4,M-20,3.42's
'07 GMC Sierra Crew Cab
'68 F-250
Old Aug 9th, 07, 08:45 PM
JimM JimM is offline
Jim
Default Re: The Commander is in, runs terrible
The "key thing" is common with the msd 6. They tend to backfeed the "turn-on" wire, everything on the ignition circuit stays hot.
Msd has a diode kit to fix it.
Then time to start tuning. First step is to check for fuel pressure in the return line, you did that, right? Must be near zero. Then set the fuel pressure, then start typing. 10 @ idle is rich, what basemap are you using?
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Aug 9th, 07, 08:58 PM
Jeff
Hmm.. never had a problem with the MSD before. Do you think if I remove the C950 switch feed from that source and find another I might fix the issue? I started with the TBI7503 map. Although I found some pretty strange values in some of the fields. I just stepped through the manual page by page and changed a few things that didn't look right. I checked the return line fuel pressure, there was none at all. On the feed side it's at 21-22.
Jeff Supinski
'68 F-250
Old Aug 9th, 07, 08:59 PM
Jeff
But I still wonder why it runs so much better with the key off. It must be shutting off something in the system...
Jeff Supinski
'68 F-250
Old Aug 10th, 07, 10:43 AM
whytry whytry is offline
Brad
Do you have a kink in the line somewhere causing the pressure to build up then release?
Founder MuscleSyndicate.com
Muscle Car Car Club
68 Camaro 468 - F1R Procharger
66 Nova - Newest Project - going LS motor, AT, and cruiser.
Old Aug 10th, 07, 10:57 PM
CarlC CarlC is offline
What is your timing measured with a timing light vs. the computer indicated timing?
Carl's Camaro
Old Aug 11th, 07, 10:06 AM
Jeff
I'm not using the ECU controlled timing. I don't have a distributor that works with it
I've got the key thing fixed and it's running pretty good. Now it's time to work out all the bugs with the fine tuning i guess.
Jeff Supinski
'68 F-250
Old Aug 11th, 07, 01:18 PM
ProdigyCustoms ProdigyCustoms is online now
Frank
Sounds like the iac is going crazy is why it is surging. The key off thing, is weird!
Frank Serafine
Prodigy Customs
Pro Touring Muscle Car Specialist
FREE PRO TOURING TECH and PROJECT PLANNING for Forum Members
Weekdays 8AM TO 10PM EASTERN TIME
FOUR ZERO SEVEN 832 1752
GP SuperStore
Group Purchase Discount Auto Parts
