Body Shop Paint & Body Forum
Old Dec 3rd, 99, 07:03 AM
denverRS/SS denverRS/SS is offline
Default
Can anyone supply me with the correct paint color for applying a black bumblebee stripe to the front of a '67 SS? Is is flat? Semi-gloss? Gloss?
Also, the back panel that the tail lights mount to above the bumper is black. Should this get the same color of paint as the bumblebee stripe?
Thanks for your help
Old Dec 3rd, 99, 11:34 PM
dropdead dropdead is offline
Default
wow tough question cant find a for sure answer for you but i would assume that they used tuxedo black for the stripe color..this is assuming that your orig stripes are painted on and not decals as was the case wit h many camaros.....ok as for the back panel it should be the same color as the car.... if not you may have an odd ball camro ... or an altered car , not sure your cars specifics but never heard of an origanal car with a diffrent colored valance pannel..ps some camaros had half decals and half paint for the same emblem so it can get confusing
Default
Old Dec 3rd, 99, 11:55 PM
Default
flat,gloss and semi gloss? the general never made a tuxedo black semi gloss paint.... they put the paint on and coverd it with clear coats and wet sanded to make the gloss content they wanted ..... krylon is what your thinking of and if so then bombcan it with semi gloss to make it look right...as my bud always say cut to fit paint to match..... laters
Old Dec 4th, 99, 08:21 PM
mccorry's Avatar
mccorry mccorry is offline
Steve
Default
The nose stripe should be gloss black.
The rear pan (around the tail lights) should be body colored for a small block car and semi-gloss (almost flat) black for a Big block car.
Steve
[This message has been edited by mccorry (edited 12-04-99).]
Old Dec 6th, 99, 07:24 AM
Default
McCorry, thanks for the reply. This car is a '67 with a 396 so that is why the tail panel is black. The paint on the front stripe has deteriorated to the point it was difficult to tell what it color it should be. Have you had any experience with the stencils to put these stripes on? I took great measurements but wonder if it is worth spending the money to get the stencil for the painter??
Old Dec 6th, 99, 04:10 PM
mccorry's Avatar
Steve
Default
Its really up to your painter. Just don't forget to leave the break for your SS fender emblem and don't put the stripe to far forward on the header panel.
