EFI in your modern Classic EFI conversions in FirstGen Camaros
Old Sep 6th, 07, 07:05 PM
JimM JimM is offline
Jim
Default racepump?
Anyone know anything, or have any opinion on this: http://www.racepumps.com
Thinking such a thing might be nice on my TBI, but wondering if/how it would work.
System needs 4 psi at idle, rising to 21 psi at WOT.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Sep 6th, 07, 07:37 PM
Doug F. Doug F. is offline
Tech Team
Default Re: racepump?
TBI needs a constant fuel pressure. The main issue I've heard about the racepumps is initial priming.
Old Sep 6th, 07, 07:52 PM
Jim
Originally Posted by Doug F. View Post
TBI needs a constant fuel pressure...
Maybe I need to read the directions again... The first 3 times I read them, it said the regulator was referenced to manifold vacuum, to set it for 14 psi at idle, and it would go to 21 at WOT.Also seem to recall it said if there was boost, the pressure would rise 2 psi per lb.
Jim's NEW Blog!
Jim Cam
Old Sep 6th, 07, 07:53 PM
Jim
cranking for even a few seconds before lightoff would bother me...
Jim's NEW Blog!
Jim Cam
Old Sep 6th, 07, 08:25 PM
scblucam's Avatar
scblucam scblucam is offline
Team Member
Scott
This is what I have been looking for, some ideas on how do it. It makes perfect sence if it will hold initial pressure while shut down. An electric pump will or will not do it.
Old Sep 6th, 07, 08:45 PM
Jim
The efi systems are set up so the instant the key goes to run from off, the electric pump is run for a couple seconds to pressurize the system.
Jim's NEW Blog!
Jim Cam
Old Sep 6th, 07, 09:10 PM
wiskeesour's Avatar
wiskeesour wiskeesour is offline
Team Member
Harley
cant you install a relay to get pressure before light off?
AE2(AW) Harley Moody, USNavy
"Master-at-Arms" for the CDWJB!!
November 26th, 2008 was my last day to serve my country as a member of the World's Greatest Navy.
Thanks Chief.
Old Sep 6th, 07, 09:15 PM
Jim
The racepump is mechanical. It replaces the stock engine mounted pump, and it can develop up to 150 psi, but only when the engine is turning.
Jim's NEW Blog!
Jim Cam
Old Sep 7th, 07, 05:41 AM
RickD RickD is offline
Team Member
The concept of the racepump appeals to me, Jim, but I've read on chevelles.com of some issues that would stop me from getting one at this time. Loss of pressure when sitting over night and, I believe, some heat issues even when using their insulator block. Their website is pretty good for info and threads.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings!
Old Sep 7th, 07, 06:03 AM
Tech Team
All EFI runs at a constant pressure with caviots. A N/A engine runs with a fixed regulator pressure. For applications where the injectors are in manifold vacuum, it is desirable to vacuum reference the regulator. This maintains a fixed pressure differential pressure. The gauge pressure when vacuum is applied is "lower", but the differential pressure is the same. TBI's are not vacuum referenced as the injectors do not see manifold vacuum.
With boost, most regulators are a 1:1, 1 psi of boost = 1 psi of additional fuel pressure. This is the SAME deal as the vacuum above. 1 psi of vacuum removes 1 PSI of pressure seen in the diaphragm. FMU's are a different beast and have a different rise curve.
Some new cars like Fords have PWM returnless pumps. They actually mimic the pressure curve of a vacuum referenced regulator.
None the less, you need a constant pressure with EFI.
Old Sep 7th, 07, 07:19 AM
Everett#2390's Avatar
Drive a '68!
Agreed, need a constant, er, continual flow, not repititive pumps.
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
Old Sep 7th, 07, 12:37 PM
Rodder's Avatar
Rodder Rodder is offline
Team Member
Jon
GM GenIII and newer smallblock EFI uses a constant pressure regulator--it's not vacuum/boost referenced. Instead they recalculate the injector flow as manifold pressure varies.
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
