long or short throwout bearing? - Team Camaro Tech
Old Sep 21st, 07, 09:16 AM
67Builder 67Builder is offline
Default long or short throwout bearing?
Anyone?
Ram 33 pound steel flywheel. summit part number RAM-1501
Ram 11" clutch disk. summit part number RAM-980
Ram 11" long style pressure plate (2400lb). summit part number RAM-436
Lakewood 15000 bellhousing with lakewood 15501 adjustable pivot ball and lakewood 15500 fork.
I figured i'd go with a ram throw out bearing just to keep with the theme, but which do i go with?
Brian F.
Old Sep 21st, 07, 11:32 AM
mbrekke's Avatar
mbrekke mbrekke is offline
Mark
Default Re: long or short throwout bearing?
Brian,
The 'flat fingered' pressure plate uses the longer throwout bearing. The plate with the fingers that are 'bent upward' uses the short bearing. Make sense?
The flat fingered pressure plates were generally used on 6 cylinder and lower performance V-8's.
Mark
'68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
'78 Firebird 350/T350 3.23 posi
'65 Mustang convert. 6 cyl. 3-speed
'66 Mustang coupe 6 cyl. auto
http://www.camaros.net/forums/member.php?u=3230
Old Sep 21st, 07, 01:48 PM
Now that makes sense.
I'll go see if i can grab one before the local speed shop closes.
Thanks!
Old Sep 21st, 07, 02:02 PM
zdld17 zdld17 is offline
Don
I dont think any of the clutch companies make their own t/o bearings, they use Timken, BCA or China companies. Last Centerforce bearing I ordered ended up having a BCA 1705C stamping. 1.250 height. If you find the industry number, you dont have to pay the extra pricing.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Sep 21st, 07, 02:43 PM
JimM JimM is offline
Jim
agree on the BCA bearing. Autozone stocks them.
Old Sep 27th, 07, 04:08 PM
JohnZ JohnZ is offline
Team Member
John
Originally Posted by 67Builder View Post
Lakewood 15000 bellhousing with lakewood 15501 adjustable pivot ball and lakewood 15500 fork. Brian F.
You may not be happy with the final position of the Lakewood fork - I'd use the GM fork.
JohnZ
CRG
'69 Z/28 Fathom Green
Old Sep 27th, 07, 08:37 PM
wagonman's Avatar
wagonman wagonman is offline
john
better listen to this guy!!!!!!!
or if you are familiar with the adj pivot ball your about to use.your ahead of the game...
just to avoid the fork from hitting the firewall.
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
Old Sep 28th, 07, 05:18 PM
SC42 SC42 is offline
Oh ya I remember the day the Fork hit the firewall...that day sucked!
Old Oct 11th, 07, 07:47 PM
Nuggettt Nuggettt is offline
Tech Team
Ditto that fork hitting the firewall!
