EFI in your modern Classic EFI conversions in FirstGen Camaros
Old Sep 21st, 07, 10:02 PM
rick rick is offline
Unhappy TPI Fuel Rail Leak
I had my system apart and now there is significant leak at the point where the pressure line enters the fuel rail. The rail is from a 90 camaro (in my 72 el camino) and the line enters at the front end on the passenger side. The leak is NOT from an O-Ring on the crossover.
It looks to me like the line is press fit & crimped to the rail. Is this correct? Is there another O-Ring here? Is there a repair procedure? Any special tools needed? Thank you and I appreciate any input on this.
Rick Schaefer
72 El Camino & Old Friend
TPI 350
Old Jan 1st, 08, 10:28 PM
Kokamo Kokamo is online now
Joe
Default Re: TPI Fuel Rail Leak
Sorry thins is a bit late, but if you are still having issues, I'll try and help.
Yes, there is a press in fitting on the end of the pass side fuel rail. If it is leaking, you need to get a new fuel rail for just that one side. I myself have not seen a repair for this yet, but that dosent mean there isint one out there.
Try E-bay or Craigslist.....there are alot of these fuel rails out there.
Hope this helps,
Joe
1969 Camaro....LS1/T-56.............
In the early stages of Pro-Touring
Old Jan 2nd, 08, 10:04 AM
Shortly after I posted, I took the rail apart. There was an O-Ring in there. I replaced it, and "resealed" the end. Its been fine ever since. I bought a generic o-ring that fit, nothing too special. Thanx for thinking of me.
Rick Schaefer
TPI 350
Old Jan 2nd, 08, 11:43 AM
Joe
Coll man, glad you got it fixed. Good to know that it is in fact repairable.
Thanks for the reply.
Joe
