Engine General Engine Discussion
Old Oct 9th, 07, 11:18 AM
1FSTLS1 1FSTLS1 is offline
Brad
Default Big Block moving ?
Does any one know about how much a big block motor with heads on it weighs in pounds? Wondering if i can muscle it into the truck myself off of the cherry picker. Or with the heads off.
Old Oct 9th, 07, 11:25 AM
William William is offline
Default Re: Big Block moving ?
You must have a death wish. Don't even think about it.
William
CRG www.camaros.org
Old Oct 9th, 07, 01:02 PM
Brad
How else am I going to get it to the machine shop? I am not scared.
Old Oct 9th, 07, 02:06 PM
1968 Camaro 1968 Camaro is offline
Tech Team
John
The engine weights about 700 pounds. You will not move it unless you do strongman lifts. Good Luck
Old Oct 9th, 07, 03:24 PM
smoksho smoksho is offline
Dave
I must be missing something here, if its on the cherry picker just back under the motor and let it down into the truck.
If you do have to lift it don't you will blow a n*** and spend more in doctor bills.
I ain't never had to much fun, but I keep trying.
67 Camaro 427 Tremec 5 speed.
64 Chevy II Nova 350 4 speed
49 Chevy Pickup 350 4 speed
Old Oct 9th, 07, 04:33 PM
pdq67 pdq67 is offline
Banned
Get a big old tire and then sit the engine in it in your bed w/ the Cherry picker, then put the C/P in and go!!
DON'T try to lift it in by yourself!! WAY TOO HEAVY!!
I have moved my BB down a rental Cargo Van's aluminum furniture dolly ramp mounted on my engine stand b/c the rear wheels cleared the sides and the front went right down the middle of it.
I used a cheap HFT come-a-long and a 2x4 across the Cab opening and some rope to pull the BB and engine stand up the ramp!
pdq67
Old Oct 9th, 07, 05:15 PM
2x67rs/ss 2x67rs/ss is offline
Andy
Yep just sit it on a tire or a 4X4 under the balancer in the rear corner of bed. Tie it down real GOOD.
Andy
67 R/S convertible Nantucket blue deluxe interior orig.
67 rs-ss coupe 555BB-400turbo streetcar/racer project
best pass 1.413 60ft. 9.959@136.34
http://s63.photobucket.com/albums/h152/67ss/The%20pair/
Old Oct 9th, 07, 05:38 PM
fatblock fatblock is offline
heavy at 700lbs for sure.I unloaded my long block without a cherry picker.I slid it out on the tailgate(after installing new tailgate cables I might add)and attached the motor stand.I deflated the rear tires..untill the motor stand took the weight and rolled it into the garage.Closed the tailgate and aired the rears back up to 32psi.
George
68 Camaro
8-71 blown 461 Rat
"The Greatness of a nation and its moral progress can be judged by the way its animals are treated"
Mahatma Ghandi
Old Oct 9th, 07, 05:39 PM
stamatisg1977's Avatar
stamatisg1977 stamatisg1977 is offline
steven
even if you were a professional powerlifter, the engine is way too awkward to lift you would never get a good enough grip
69 Le Mans blue SS X-55 soon to be LS3
Tremec TKO 600
http://community.webshots.com/user/stamatisg1977
Rich Christensen is a tool
Old Oct 9th, 07, 07:24 PM
viperjesse viperjesse is offline
Jeff
I lowered my BBC onto my 2000 F-150 tailgate and it smashed the tailgate down. You can't see it from the outside, so I added a bed liner to hide it.
I took the tailgate off to get it out.
Old Oct 10th, 07, 04:51 AM
Brad
Thanks all. I think I can put it in the back of my tacoma. Moving the cherry picker acros the drive way sound like it may be hard.
Old Oct 10th, 07, 12:00 PM
Vintage 68's Avatar
John
Wink Re: Big Block moving ?
As was suggested earlier, back you're truck under the picker and lower engine into truck.
IF, you do try to move the picker with the engine swinging (operative term here!) from the boom, make sure you lower the engine mass to the lowest position possible before you try.
Originally Posted by viperjesse View Post
I lowered my BBC onto my 2000 F-150 tailgate and it smashed the tailgate ...
Big Block Chevy's hate Ford tailgates
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and a Straight-Six...
Modesto - the Gateway to Turlock
If I can't fix it with a hammer - it must be an electrical problem ...
Old Oct 10th, 07, 12:09 PM
Fred Ficarra Fred Ficarra is offline
Fred
Brad! One more thing. Be sure to have a friend video your attempt. It might be great for utube!
One owner 69 Camaro,(yep, bought it new) RS SS Hugger Orange, L88, 4:10 posi, ducted hood and best et 11.59, 1.5's 60'. All with 1960's stuff. (except tires and converter)+ MT Super Scavenger headers. OK FI too.
http://epitomesrebuild.com/
Old Oct 10th, 07, 12:49 PM
Brad
I figure the least I have to do is lift the motor then bacl it up 3 feet drop it down spin it around lift it up and back the truck up to it and put her in. Simple
Old Oct 10th, 07, 07:30 PM
wannarace wannarace is offline
I admit this is hard to believe but I know a guy that used to pull small blocks out of cars by HAND.. No cherry picker. Just reach down over the front and pull it out. They hated him at the bowling alley to because he threw the ball hard enouth to break pins. A bare small block is all I want to lift.
75 camaro circle track car. LW Eagle on the bottom, Dart on top.
92 Chevy Stepside pickup. BBC+T56=BIG fun and a LOT of smoke...
