| Team Camaro Tech Current Topic: key resistor | ||
| Fourth Generation 1993-2002 |
How can I get to it and how do I clean it?
The resistor is in the key in your hand.What is your issue????
George 68 Camaro 8-71 blown 461 Rat |
my car won't start and someone told me to check the key resistor cause it might be dirty
The black thing with the silver stripe on each side.
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
may be the contacts on the iginition switch that the resistor mates up with?
1969 Camaro SS 350/300 M20 12 Bolt 3:73 Posi
Danny..The most common failure is in the column.The lock cyl rotates and the orange Vats wire flexes and breaks over time,causing an open ckt.You can remove the steering wheel and visualy check this or get a gm tech to hook up a vats interrogator at the base of the column.You can measure your key pellet resistance with an ohm meter then disconnect at the base of the column and with the key in ignition..measure the resitance.I bet your dvom reads OL.
Can a resistor be placed in the harness plug to allow starts prior to replacing the ignition lock cylinder?
Oh no. The cats outta the bag now.
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
| Sponsored Links | |
Advertisement | |
