Rear Suspension - Team Camaro Tech
Old Oct 20th, 07, 07:59 AM
vanmelum vanmelum is offline
Thomas
Default Rear Suspension
So I finally am going to suck it up and want to beef up the suspension. I have the original leaf springs (that have been bent back to shape once) and know that it is time to get new everything.
However, I don't know a lot about suspension. If anybody could give me some links where I could start teaching myself about it that would be awesome. Or if you have opinions on what is good that would be great too. Thanks.
PS I have a 1971 Camaro w/ zz4 crate motor, tremec 5 speed, posi 12 bolt rear end, 3.73 gears (is that enough info?)
Thomas<br><br>1971 Camaro w/ HO-350, hooker headers, TKO-600, 3.73 12 bolt rear end, straight body, straight lines, no dents, no rust, horrible paint job. Next month...
Old Oct 20th, 07, 10:22 AM
pdq67 pdq67 is offline
Banned
Default Re: Rear Suspension
Contact Eaton Spring b/c they probably have a pair of h-h leaf springs that will do you fine in their 1,000's upon 1,000's of spring spec's..
OR if you want to spend some cash for SPECIAL springs, then contact Chicane and have him set you up with a pair of the h-d CUSTOM made traction-bar eliminator springs w/ the 2nd leaf that wrap's partially around the front spring eye's..
pdq67
Old Oct 20th, 07, 10:23 AM
Steve69SS396's Avatar
Steve69SS396 Steve69SS396 is offline
Steve
What do you want to do with the car? Drag race, street/strip, handling, mud bog, hill climb, sand drags?
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Total Seal rings, hand ported AFR 210 heads, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .660" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 8" converter
Old Oct 20th, 07, 06:33 PM
Thomas
Its just a weekend warrior car....I don't care about rough ride (not like it isn't rough already) I just the body to stay over the tire when I turn...I want it so that when i punch it...you don't see the front fly up and the rear end sink...
You know...I just want it to have that solid look and feel. Not blow your brains out drag or rally racing....but leaning in that direction.
Follow that?
