| Team Camaro Tech Current Topic: Big Block Tem | ||
| Engine General Engine Discussion. |
Can anyone tell me what tem should a big block chevy run how high should it
get before its to hot? |
| Sponsored Links | ||
Advertisement | ||
I would suspect between 180*F to 200*F, however, a trip to 210*F is occasional.
It will be interesting the poll of answers.
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
Dill..i would run it hot enough to burn of crankcase water vapor.Oil temps are typically hotter than coolant temps after a complete heat cycle..so regulated coolant around 190 should have the oil over 212F to vaporize condensation in the base.I would say for coolant temp..my max would be 230F.Creeping up to 210-215f in traffic is not desireable,but should not create any issues if the temp returns to 200F and under at cruise.
George 68 Camaro 8-71 blown 461 Rat |
I "really like" my hot rod motors to run at 180, maybe 190... If they run hotter I'd consider it something that needs fixing.
Truthfully tho, it ain''t gonna be hurt till it's over 230.
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
190 here , all summer long , even in heavy traffic
I have had an insight on automotive cooling systems. Something I always knew in pieces/parts but never added it all together into a realization.
The biggest problem and the biggest reason for variance in car cooling systems derives from the fact that they rely on speed induced airflow to compensate for incredibly undersized heat exchangers. Think about it, cruising down the highway your car is only using about 50 HP. In fact I've worked on lots of industrial 50HP engines that have radiators 50% larger than a cars. Idling in traffic at 220° is a result of the engine working it's *** off to pull a vacuum against the throttle blades while lugging a torque converter, alternator and AC and PS.... and low air flow through a radiator that couldn't accomodate a 50HP stationary load. Put a bigger radiator and fan when in doubt ![]() This is a little 900HP heat exchanger. Top is water, bottom is gas.
Tim Smith |
My 427 sometimes burps antifreeze after I stop. I have idiot lights on mine and the temp light is usually if I start up after a burp, but before it cools (like if I stop for gas). The light goes off within 30-45 seconds of driving, even at low speed. Since the light is on in these conditions, I figured it wasn't a bad thermostat or rad cap. Any advice?
| Sponsored Links | |
Advertisement | |
