Looking for headlight fuse location... - Team Camaro Tech
Thread Tools Display Modes
Old Oct 29th, 07, 06:00 PM
PeterPenguin PeterPenguin is offline
Jake
Default Looking for headlight fuse location...
My son's 1992 V8 Camaro has had it's headlights fail.
In looking around in the Haynes manual, I can't find any information about the location of the headlight fuse. It says in the electrical diagram something about a 'rust 20A'.
I managed to pretzel down to look, but can't see any 20A fuses blown, or any fuses blown.
So my simple question is... WHERE is the headlight fuse on the 1992 V8 Camaro?
Is it anywhere on this fuse photo I took? Or is it somewhere else?
Any other culprits to suspect beyond both headlamps burning out at the same time?
Thanks for any clues...
PeterPenguin
Old Oct 29th, 07, 06:24 PM
eville eville is offline
Team Member
Steve
Default Re: Looking for headlight fuse location...
Is there a fuse box under the hood? My Civic has two fuse boxes. Horn, headlights etc was under the hood. Those headlights usually do give out about the same time, but usually days apart not minutes apart. Unless... there is something else going on........
Steve
1968 Coupe., filled with cool stuff from Tremec, Moser, Ron Davis, Speedtech, ATS, Hotchkis, Forgeline... blah blah blah
Check it Out Here
Old Oct 29th, 07, 07:35 PM
Jake
Well we looked, but couldn't see any. I've had a few cars with fuses under the hood... but it doesn't seem like that's the case here.
Thanks anyhow... anyone else know where it might be? Or is it one of the fuses in the photo above?
That Haynes manual really isn't all that helpful. From the photo I can make out ECM (electronic control module?), INJ 1 (injector 1), L1D (no idea what that means), Heater A/C, Fan, Turn signal, Back Up, Tail lights, Fan, Gauges, SIR (no idea), ACC, WDO (no idea), Instrument lights, Radio, Battery, Stop Hazzard lights, Wipers... but NO main headlights!
It also seems some of the fuse slots are empty... but I don't know if that means those components don't exist on this model.
Ignorance is not bliss when it comes to automotive mechanics!
:0)
Old Oct 29th, 07, 08:14 PM
dnult dnult is offline
The glove-box manual would tell you where the fuses are all located and will also deliniate their location.
You headlamps could be powered through a fusable link or a breaker. There might also be a relay involved. Unfortunately I am not well versed on 92s.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Oct 30th, 07, 02:41 PM
I did some checking in my 2002 diagrams (for what it's worth). I noticed that Domestic camaros used fusable links for the headlamps, while Japanese and Euro Camaros had fuses. What's more the fuses were in-line near the lamps - not in a fuse box.
I would imagine your car uses fusible links.
Dave
Old Oct 30th, 07, 05:18 PM
novaderrik novaderrik is offline
if it's like any older GM car back to at least the mid 60's, then the switch has a self-resetting breaker inside it. if there is no short circuit anywhere and it won't reset itself, it's time for a new switch.
of course, get in there with a test light and verify that there is power actually getting to the switch before buying a new one. it's also possible that the hi/low beam switch on the column is bad, as well.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: Looking for headlight fuse location...
Location
Location
First Name
Human Verification
