measurments - Team Camaro Tech
Body Shop Paint & Body Forum
Old Nov 1st, 07, 08:25 PM
Carolina67Ragtop Carolina67Ragtop is offline
Default measurments
I'm looking for body measurements. I've found frame measurements, but in need of measurements in the door area. I need them from back to front,so I can brace it properly. She is a 1967 vert and is flexing a bit. Anyother information with #'s would greatly be appreciated.
Old Nov 2nd, 07, 07:26 PM
jus4funn68 jus4funn68 is offline
Default Re: measurments
Im not sure you are being specific enough with your question. Back of the door...back of the car to the back of door... quarter panel to the fender???? More info would help. Kevin
68SS 396/375 L-78 Camaro
68 Chevelle
Old Nov 2nd, 07, 08:00 PM
Eric Kammerer Eric Kammerer is offline
The question is specific enough, but...
With car to car variability, difference in measuring points and measuring devices, etc., it can be tough to get meaningful info.
Is this bracing your adding a long term fix, or just to hold it while you replace something that's rotten, like rockers or floor or???
Do you have the 67 Assembly Instruction Manual (AIM), and/or the 67 Fisher Body Manual (FBM)? It may be that the best way to approach it is to jack/crib it up underneath at key points, make sure the door to quarter, door to rocker, and door to fender gaps are in spec, and then tack your bracing in. That way, you're setting it up in a way that you now will work for your car, and aren't going to result in some nasty surprise later when you find out I measured from the stickout for the door jamb switch to the striker mount, and you measured from the bottom of the telephone indent to the 4th hinge bolt hole, and you have to shave the door.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Nov 4th, 07, 06:30 PM
sharpie sharpie is offline
Rich
If you got body flex the rockers are shot and should be done.
As for the door measurements,No car will be the same everyone would measure from differnt points so youd end up with alot of numbers, What I did was jacked and twisted the body to get the gaps where I wanted them, Then -X- braced the door opening. Did that side put the door back on and checked that everything was good,then final welding BEFORE doing the other side.
Take as many measurements off your car as possable.
Rich
68 Camaro convertible
67 SS Chevelle Wagon 350,TKO 5 Speed,True fire flame job
You grin ear to ear driving this bad boy!
http://i140.photobucket.com/albums/r...rgeWebview.jpg
