700r4 - Team Camaro Tech
Old Nov 7th, 07, 05:01 PM
67cams 67cams is offline
Smile 700r4
Hello, thinking about putting in 700r4 in my 68 camaro, what crossmember and what size drive shaft would i need.?? the car has a 10 bolt with a 350 engine..thanks..
Old Nov 7th, 07, 05:30 PM
onovakind67 onovakind67 is online now
Default Re: 700r4
The crossmember will have to be slid about 2" rearward and re-bolted. If you have a stock TH350 or manual tranny, you will need a 3" shorter driveshaft.
Old Nov 8th, 07, 07:16 AM
TJS69 TJS69 is online now
Tom
Talking Re: 700r4
After the 700r4 is installed, you can measure to have your driveshaft shortened or custom made. You can buy a crossmember from places like Bowtie overdrives, if you wish. I have a modified TH 400 crossmember but, it was modified alot to fit properly.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
