Test Drive! New to this area?
Get comfortable here by posting and editing your own messages.
Old Nov 8th, 07, 09:05 PM
bjrs68 bjrs68 is offline
Bill
Default RS Headlight Routing Check Valve & filter
Just got a 68 convertible RS/SS. Vacuum headlight system is new but incomplete. The filter and check valve were not installed. From 68 and 69 diagrams I can't figure out where to put these two. 68 has two outlets on the vacuum retention tank, 69 appears to have one. Can't figure out placement of the check valve that has three ports (2 larger, one small). Anyone know what to do with this? I'd love to get this done soon. I'm sure to have more questions later as a newbee to all this.
Thanks,
Bill
Old Nov 9th, 07, 07:22 AM
west 68 west 68 is offline
Gold Member
Default Re: RS Headlight Routing Check Valve & filter
bill the 68 69 are different the 68 only uses filter which is located about 4 inches from tank on the outboard side of the two fittings west68
Old Nov 9th, 07, 11:27 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Bill you posted this question in a 'test section' where folks try out signature lines and practice posting pictures. You need to hop up to Tech Section with your question.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto.
Our Camaro Webpage
Photos for viewing
Learn How To Post Pics here
