K&N X-Treme Air flow assembly - Team Camaro Tech
Old Nov 12th, 07, 05:31 PM
andy vincent andy vincent is offline
Tech Team
Andy
Default K&N X-Treme Air flow assembly
my stock air breather filter is a 14"...the sizes available are 9,11,14" my question is is there any advantages/disadvantages to using a smaller filter or larger one
if you are not familiar with this product heres a link:
http://www.jegs.com/webapp/wcs/store...10002_92772_-1
Old Nov 12th, 07, 05:43 PM
wannarace wannarace is offline
Default Re: K&N X-Treme Air flow assembly
The bigger the air filter is the more air flow you will get out of it. If you want the extreme air flow lid the 9" filter is plenty for a street motor. Smaller filters will give you more room under the hood. I would recommend the 14" filter with a crome lid because I think they look better. It will out flow a stock element by far.
75 camaro circle track car. LW Eagle on the bottom, Dart on top.
92 Chevy Stepside pickup. BBC+T56=BIG fun and a LOT of smoke...
Old Nov 13th, 07, 06:17 AM
67CamaroRS/SS 67CamaroRS/SS is offline
Charlie
There is a formula to finding out how big an air filter to use.
A=CID X RPM/20,839
RPM= Maximum power RPM
For example I have a 350 so I would take 350 x 6200RPM / 20,839=104 Square Inches.
Then to find out the height of the filter use this formula.
H= A / D X 3.14 + .75
A= Affective filtering area from 1st formula.
D= Outside diameter of filter
.75= rubber end caps of filter.
So again my example would be
104 / 14" x 3.14 + .75= 3.12
I would need a filter that measured 14 x 3.12 for optimum air flow. That's getting down to nitty gritty.
Here is a link to the formula in case I confused you...
http://www.knfilters.com/filter_facts.htm#RESULTS
Charlie Knudsen 67 Camaro RS/SS 350 TKO 600, 4.10's, AFR 195 Street Heads, Comp 270H, Rhoads Lifters, Crane Ignition, Pertronix Dizzy, Performer RPM Q-Jet, Heavily Modified Q-Jet, Hooker Comp Headers, MagnaFlow 2 1/2", 144 Decibles(Alpine CDA-7998 Head Unit, RF X7 and RF 750X Amps, MB Quart Mid's & High's, Kicker L7 12" Solo Barics)
Old Nov 13th, 07, 07:15 AM
dylanjans dylanjans is offline
a test hot rod did quite some time ago showed the differences on a zz454 crate with an eddy rpm air gap, a JET 850 carb, HEI, 1.5 inch wilson spacer, CSI electric pump, and hooker 2" 2213 headers
all K&N filters
HP/TQ
open carb: 502/534.3
carb w/ stubstack: 507/537.5
3 inch element with drop base: 505/534.5
3 inch element with drop and xtreme top: 499/532
3 inch element with drop and xtreme top, stubstack: 506/536.1
4 inch element with drop base: 506/537.9
4 inch element with drop and xtreme top: 507/539.6
4 inch element with flat base and stubstack: 509/538.4
4 inch element with flat base, stubstack, and xtreme top: 507/540.5
4.5 element K&N flow control w/ xtreme top: 508/539.8
Old Nov 13th, 07, 08:18 AM
Vintage Musclecar Vintage Musclecar is offline
Might check out this response on the subject by Joe Sherman.
Eric
Carburetor Rebuild & Restoration
www.vintagemusclecarparts.com
