Lucas Transmission Fix in a bottle. Any good at all?? - Team Camaro Tech
Old Nov 16th, 07, 12:20 AM
nikkisdad nikkisdad is offline
mike
Default Lucas Transmission Fix in a bottle. Any good at all??
Guys, I have a old Ford Explorer that has some trans slipping problems. I just want it to go a little longer, then it can die peacfully, no viewing, just in the bailer. Does this stuff work? Say I dumped the fluid, added a couple of quarts of this and topped it off would it change anything, or is it a waste of money, thanks for any response.
Old Nov 16th, 07, 12:23 PM
wiskeesour's Avatar
wiskeesour wiskeesour is offline
Harley
Default Re: Lucas Transmission Fix in a bottle. Any good at all??
Thro it in Mike. I like it. It does work for slipping and erratic shifting. Filter woudlnt hurt if its cheap enough.
I like it irregardless. IMHO...All Lucas stuff is good stuff.
AE2(AW) Harley Moody, USNavy
"Master-at-Arms" for the CDWJB!!
November 26th, 2008 was my last day to serve my country as a member of the World's Greatest Navy.
Thanks Chief.
Old Nov 16th, 07, 12:52 PM
BERRY251 BERRY251 is offline
BERRY
Check out this out!!!
http://www.camaros.net/forums/showth...t=lucas+result
Its cheaper to be poor!
Old Nov 16th, 07, 01:02 PM
mbrekke's Avatar
mbrekke mbrekke is offline
Mark
Berry,
That link is about oil treatment.
Mike,
I had a transmission in an old Celebrity that sounded like marbles in a tin can. Put in a couple pints of trans fix and it smoothed out after a day or two of driving around, and lasted years till we sold it. Not sure how well it would work on slipping, but it's cheap enough to try.
Mark
'68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
'78 Firebird 350/T350 3.23 posi
'65 Mustang convert. 6 cyl. 3-speed
'66 Mustang coupe 6 cyl. auto
http://www.camaros.net/forums/member.php?u=3230
Old Nov 16th, 07, 01:13 PM
CDJr CDJr is offline
CDJr
Ya, I agree, Mike, I like it. Ive used it in my wifes Camry and a couple of my work trucks (all 3 of which are/were regularly abused) and it worked like a charm
Old Nov 16th, 07, 02:58 PM
tomg tomg is offline
Tom
I used it in my Th350, worked great!!!
Tom
67 RS B/N Yellow
Old Nov 16th, 07, 04:20 PM
BERRY
Berry,
Yes I know it is oil treatment, but I figured I would throw it out there because if it does that to engine oil......who knows???? LOL
Old Nov 16th, 07, 08:18 PM
johnnyr johnnyr is offline
Johnny
I've used Lucas trans fix in several different transmissions, I love it in high mileage transmissions it works for me. hope that it helps you as much as it has me.
1967 RS/SS 396 Camaro
Old Nov 16th, 07, 09:03 PM
dnult dnult is offline
I know nothing about the Lucas product so take this for what it's worth. Have you ever dropped a carberator in cleaner and found the o-ring you forgot to remove before hand. The O-ring will be larger, softer and unfortunately brittle. Some of those miracle-in-a-can tranny additives do the same thing. While it will give temporary relief, the blessing is short lived as the seals eventually break. I just urge anyone contemplating a transmission fluid additive to read the fine print and don't expect an additive to fix a failing transmission. On the other hand, it sounds like you're headed for a rebuild anyway so what do you have to loose in this case.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Nov 16th, 07, 09:17 PM
dbx1969 dbx1969 is offline
Kevin
I can vouch for Lucas products in general. I've been using their injector cleaner for years. And fwiw, the guys at two different auto parts stores say that Lucas is the only brand they'll use as a tank additive that works.
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
