Head gasket for Trickflow 62cc heads - Team Camaro Tech
Old Dec 1st, 07, 11:34 AM
DenRS's Avatar
DenRS DenRS is offline
Default Head gasket for Trickflow 62cc heads
I finally got my engine apart and I getting ready to intall my new heads and cam. I'm currently painting my block so I haven't installed the heads or cam yet. The head gasket that came in my engine kit is a felpro .041 compressed thickness, but I think this might be to thick. My block was decked at one point since there are no numbers on the front pad, but I don't know how much yet. I do plan on measuring how far my pistons are in the hole, but I have to finish painting the block first. My pistons look like the ones in the link, except my pistons don't have the little circle in the middle. They seemed dished, but how do I figure out how much? I'm trying to figure out how to get my compression ratio around 9.5 to 1 for my cam. Does fel pro make a head gasket that I can use with aluminum heads that is thinner than .039?
http://www.chevelles.com/forums/show...headers&page=2
1969 Camaro 350, Trickflow heads, ST-10 4spd, Hotchkis suspension, Baer SS brake kit, moser 12bolt
Old Dec 1st, 07, 12:02 PM
Mark .L.W. Mark .L.W. is offline
Default Re: Head gasket for Trickflow 62cc heads
You need to check how far down the pistons are , do you have the heads off now . If it's at zero deck now you can't go much thinner or the pistons will hit the head .
Mark.
pictures can be viewed at http://photobucket.com/albums/b247/mark69rs/
Old Dec 1st, 07, 12:21 PM
zdld17 zdld17 is online now
Don
Set some type of straight edge across piston hole with piston at TDC. If this is the best you can do, slip a feeler guage between the straight edge and the outer edge of this piston in the photo. If this is your piston, it looks like you have an outer rim and that would be considered the highest point so use that and not the full dish.
Now , if you can come up with a piston part #, that should solve the rest of the equation. I used the .039 1010 flepro gasket too, thats the thinnest I could find in a composition. .035-.045 would be considered safe by some standards but I have seen steel rod motors with less but you are not from Malvern , Pa, so forget that.
Here is a little program to figure what gas you could run, just input the unknown .
http://www.bid2race.com/DynamicCompr...Calculator.php
Here is a link to a compression program by Pat Kelly. Down at the bottom of this are the programs that you could load and run. Determine Dcr and Scr.
http://cochise.uia.net/pkelley2/DynamicCR.html
If you can get that piston #, it would be easier. Did you say if these were cast , forged, aftermarket? Is there a number stamped on deck? They look like a TRW 2556 piston.,
Using the numbers you provide on a 350, with 12 cc pistons, +- .20 deck, .039 gasket, 62cc head, I keep coming up with 9.3scr / 7.7 dcr with your 268 cam. Your quench is about .060
With the 6 cc piston stuff changes, 8.2 dcr / 9.9 scr. This looks like the piston I had in my 355 and that piston was a 6.1 cc piston.
What did I miss.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Dec 2nd, 07, 08:19 AM
DenRS's Avatar
I'll check the piston numbers. Where are the located? Are they on the bottom of the piston?
Old Dec 2nd, 07, 09:11 AM
pdq67 pdq67 is offline
Banned
I think those are just stock, -12 cc dish pistons .
And you can use Fel-pro's #1094 headgaskets with aluminum heads.
They are the .015" thick, rubber coated shims.
But please don't take my word on the pistons b/c if it was mine, I'd cc both them and each head to be sure.
I use this CR. calculating program.
http://www.campbellenterprises.com/R...alculators.htm
pdq67
Old Dec 2nd, 07, 12:23 PM
Don
Usually stamped on top near reliefs, but like Paul said, you may be able to just cc them. Get the piston level and drop some measured fluid into the dished portion. You can use a hypo syringe from a farm store.
Don
TC # 349
Old Dec 3rd, 07, 07:17 AM
DenRS's Avatar
I'll have to clean the tops of the pistons because I didn't see any numbers on them.
I attached my dial indicator to the block and set the indictor to the outer edge of the pistons. When the piston stopped moving up according to the dial indicator, I got out a straight edge and checked the edges to check how for the pistons were down. I measured .030 down. Does this seem correct? I thought stock was .025 down. What did I do wrong? My front pad has no numbers on it, so I would assume that it was decked before the last rebuild. Shouldn't my pistons be less than .025 in the hole? Bear with the stupid questions, this is my first rebuild.
Old Dec 3rd, 07, 08:38 AM
Everett#2390's Avatar
<Jake 68's Rule
You can use the dial indicator to measure the depth.
Bring piston up to TDC with the Dial Ind.
Move D/I over to the block deck, zero the ind.
Place D/I directly above the wrist pin, front to back on the piston, and measure the depth.
Usually, the OE depth is 0.025", if you are measuring at the side of the piston, 90* to the wrist pin, then piston may be cocked in the bore. 0.030" is not bad, just have to add it to the formula.
Aftermarket numbers are stamped on the top.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Dec 3rd, 07, 10:19 AM
DenRS's Avatar
Ok, I measured it at the top of the piston. I'll recheck it later on as I have some errands to run for the rest of the day. I did just finish cleaning off my pistons. The numbers on the pistons are 423NP .060. Just found out I have a 4 bolt main too.
Old Dec 3rd, 07, 03:48 PM
Banned
You might have DITH rebuilder pistons so a deck plane could be done is why they are .030" vs the usual .025".
Like DITH of say a .040" and then a .010" clean up cut leaves them at .030"
Get my drift.
pdq67
Old Dec 7th, 07, 05:47 AM
DenRS's Avatar
I think my pistons are sealed power cast dished pistons. Does anyone have a sealed power catelog and can look up the dish volume of my pistons. I could not find the dish volume of my pistons. The numbers on the pistons are 423NP .060.
Old Dec 7th, 07, 07:08 AM
Don
Sealed power. H423NP .060
http://www.flatlanderracing.com/trwchevy350.html
Part # Notes CIDComp Ratio CompDist PistonShape Price/
Each
58cc 60.5cc 64cc 68cc 72cc 76cc
H423NCP-60 5.7" Rod 361 9.56 - 9.00 8.67 8.36 8.08 1.540 .070 dish $16
Don
TC # 349
Old Dec 7th, 07, 09:52 AM
Eric68 Eric68 is offline
Eric
When I used the TFS 23* heads on my old 383 I really had good luck with Victor Reinz Nitroseal gaskets. They have a graphite coating on them that sealed good and did not mark up the heads. Very easy to clean up when taking things apart. They have a few different thicknesses -- I am pretty sure there is one that is 4.100" bore by .026-.028" thick. if you search on "Nitroseal" in the Performance forum I am sure I have posted part numbers and thicknesses in the past.
Make sure you measure your deck height and don't go any tighter than about .033-.034" with your quench. My old 383 was OK at .033" but my new 410" motor was carbon tracking at the same quench and I had to open it up with a thicker gasket.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Dec 7th, 07, 04:17 PM
DenRS's Avatar
Thanks for the link. What does .070 dish convert to in CC's?
Old Dec 7th, 07, 06:58 PM
Don
I am gonna guess 15 -18 cc = .070. Not knowing much more than what you have posted. . You could take a vet syringe measured in cc's and fill it with water or varsol and fill up that area and get pretty close.
Don
TC # 349
