Billit Tail Lights With Led - Team Camaro Tech
Camaro Tech General Tech Area
Old Dec 12th, 07, 03:32 PM
Cardi Cardi is offline
Brandon
Default Billit Tail Lights With Led
I hope this is the right section for my question, I apologize if it isn't. I have a 69 RS Camaro, and want to buy the custom billet RS tail lights from Marquez Design, but also wanted to get the 69 RS Sequential Led Lights, just wanted to make sure the 2 would work with each other, thanks alot.
Old Dec 12th, 07, 03:42 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Default Re: Billit Tail Lights With Led
I have the RS billet tail lights from Marquez. I used the factory bulbs in it and also added the bulb to the backup light socket. My car was not a RS car, that is why I put the bulb in the back up light socket. I like the way they look with the regular bulbs because of the lense material that Marquez uses. I also have the led light set for the other car I am doing but will not be using them because I think it is a waste of money. Now if you use factory lenses then the led lights would look good.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Dec 12th, 07, 04:07 PM
Brandon
Hmm, thanks alot for the advice, when you get time if you could by any chance could you post some pics?
Old Dec 12th, 07, 08:05 PM
guccieng guccieng is offline
the sequential lights, or 'digitails' are made by american auto wire. they come with a diffuser that goes on the inside of the lenses to disperse the light and get rid of the dots that leds seem to make. marquez tail lights do not need the diffuser. they work fine together.
Old Dec 13th, 07, 05:16 AM
DougP's Avatar
DougP DougP is offline
Doug
Like prostreet69camaro I opted to keep the original bulbs when I installed the Marquez Design tailights -- they are bright and work just fine
==Doug
Former 69 Camaro owner
Former 70 Pro Street Nova owner
Former 2nd 69 Camaro owner (pics of resto project)
Old Dec 13th, 07, 07:04 AM
Brandon
Thanks alot guys. Helped alot.
