Location of Freeze Plugs - Team Camaro Tech
Old Dec 16th, 07, 11:17 AM
Frankrentef's Avatar
Frankrentef Frankrentef is offline
Default Location of Freeze Plugs
Greetings all,
With about 40 years of grit, dirt and oil on the engine I'm having trouble identifying where the freeze plugs are located. Can anyone give me a "road map" as to where and how many they are?
I've got a small drip and one of the older local shade tree guys said it was a freeze plug. I'll be darn if I can find exactly where it's coming from. Sometime is leaks a little and sometimes not at all.
The guy I found the car / obtained it from said he put in rubber freeze plugs and that one was leaking and would need to be replaced... hence the direction of my search.
1967 RS 327 w/factory air - 2bbl Rochester carb
67 Camaro RS - 327 c.i.
Matching #'s - w/Air
"A work in progress"
Old Dec 16th, 07, 12:56 PM
dawg's Avatar
dawg dawg is offline
Harry
Default Re: Location of Freeze Plugs
really easy
there are 2 on the front of the block
and the side has 2 maybe 3 on each side.
they are round indentations
Dawgs 69
406 stroker
us navy retired
http://www.northeastf-bodyassn.com/
Old Dec 16th, 07, 01:04 PM
zdld17 zdld17 is offline
Don
8 in all. Two in front, four on side (2 under each motor mount ), two in back of block behind flywheel. All are 1 5/8". Use brass for the replacements.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
pdq67 pdq67 is offline
Banned
And he forgot the two that are on the rear of the block behind the flywheel/flex-plate under the bell-housing!!
pdq67
