cam for torque....110 or 112 LSA????? - Team Camaro Tech
Thread Tools Display Modes
Old Dec 29th, 07, 10:07 PM
dubs68camaro dubs68camaro is offline
Default cam for torque....110 or 112 LSA?????
Yes.....I'm still trying to find just the right cam for my tow vehicle, now that I have the carb and intake on the shelf. Here's the questions:
I'm trying to ween myself from only going with Comp cams stuff. They list a their best 454 towing cam to be a 268H with LSA 110 and both valves listed at .485.
Every other cam manufacturer (crane, crower, lunati) seem to list a split duration with the exhaust side having both more duration and lift. Some also have a LSA of 112-114. I'm just trying to get huge grunt, but don't care about gas mileage. Is the spilt cams the way to go??? How can a bigger LSA help my low end???
Last questions is the crane energizers. I can't believe that jeg's lists a cam AND lifter kit for only $129 plus the $11 shipping. How reliable are these Crane cams??? I've never run one. Thanks!!!
Old Dec 30th, 07, 12:04 AM
BlackoutSteve BlackoutSteve is offline
Steve
Default Re: cam for torque....110 or 112 LSA?????
Tighter LSAs tend to raise torque to a higher rpm as well as reduce overall torque.
http://www.webcamshafts.com/pages/cam_glossary.html
Scroll all the way down..
Nov 68 Van Nuys. 327 floor-shift-auto, Frost Green and not much else when new.
http://img233.imageshack.us/img233/3...sychedelic.jpg
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
Old Dec 30th, 07, 03:27 AM
kemper68rs kemper68rs is offline
Mike
Relax man... the 268 will be nice for your intent use. I promise you!!!
Old Dec 30th, 07, 07:28 AM
lluciano77 lluciano77 is offline
I ran the 268H for SBC on my old 307. On that engine the bottom end made it feel like a healthy 350. The RPMs kept pulling well into the 6,000 range. I would imagine the BBC version will be designed similarly.
Comp Cams almost always uses a 110o lobe. I don't know why. I personally prefer a 112o or a 114o lobe on a street car, but I am sure a lot will disagree. They will both rev slower than a 106o-108o lobe, but my SBC 400 is not built to be a wind up toy, and neither is your tow rig. You get a better idle, vacuum, and response from a 112o-114o lobe.
Split duration/lift only helps when your intake/exhaust ratio is low on the exhaust side. You can research your heads to find out where yours are, but honestly I don't think it will be worth the effort on a tow vehicle.
Old Dec 30th, 07, 07:34 AM
onovakind67 onovakind67 is online now
No need to use a lower case o or an * to indicate degrees. You can easily get the degree sign by keying Alt-0176...
Old Dec 30th, 07, 07:37 AM
pdq67 pdq67 is offline
Banned
Max grunt at a price of lower rpm's will be created w/ a duration at .050", 210/218, 112/108, max. lift cam.
That said, Harold recommends his....
272/217, 112/? .515". The best cam for pulling trailers, car-hauler or boats. Excellent bottom end and mid-range torque. Works power accessories. 1600-5500 rpm.
pdq67
Old Dec 30th, 07, 07:40 AM
Hold ALT and which key???
Old Dec 30th, 07, 08:27 AM
Hold the Alt key down, key in the number 0176, then release the Alt key.
You can get more codes from your character map, under system accessories.
Alt0174 =
Alt0178 =
etc..
Old Dec 30th, 07, 09:00 AM
Hey guys.......you are in the wrong forum!!!!!
These topics need to be moved to:
teamcamaro/nerd/coolthingsyoucandowiththealtkey/toomuchtimeonyourhands/p34spacemodulator
LMAO just kidding!!!!
Old Dec 30th, 07, 10:03 AM
77wolf10.85's Avatar
77wolf10.85 77wolf10.85 is offline
Tim
LSA is in cam degrees°
ICL is in crank degrees
Think of the lobes for a given cylinder as carats ^
i e
As LSA decreases the lobes move closer together
and a 3rd ^ is created betwixt the 2 that represents overlap. Think of overlap as a time period when both valves are open and the engine can't accomplish much down low. The slower the engine is turning the greater the time period, and the converse as well.
So, minimizing overlap maximizes bottom end ballz. Overlap is increased by tighter LSA as well as by increasing dur on the exh. or on both lobes.
Hope this helps.
° hafta use the numpad numbers, the numbers above your letters don't do it °
numkeys on laptop don't work° °but the blue ones do
hafta hold blue bastard and alt then find the 0176. This is easier...If on a laptop just C/P to Notepad and alt ee into TC
Tim Smith
  #11
Old Dec 30th, 07, 12:30 PM
Banned
Generally, a wide LCA cam like a 112 to a 114 raises each end of the power curves, but lowers the overall peak power numbers. Narrower overlap like Tim's talking about.
Therefore a narrower LCA cam like a 108 to a 106 lowers each end and raises the peak power numbers! Wider overlap so it will be choppier!
There's a heck of a lot more to this, but GENERALLY speaking.
pdq67
  #12
Old Dec 30th, 07, 01:02 PM
CamaroZZ430 CamaroZZ430 is offline
Tech Team
Rick
Crane Cams are very reliable and have been around for years. I would run the crane with a 112 and split duration. I really think that a cam with the duration that you are talking about its not going to make a whole lot of difference which one you use, just pick one and put it in. I would be more worried about gearing for a tow vehicle
  #13
Old Dec 30th, 07, 01:27 PM
I think with the 3.73's that are in the a** end, gearing isn't going to be too big of an issue!
  #14
Tim
What Harold has said on the topic
http://speedtalk.com/forum/viewtopic...rque+lsa#79526
http://speedtalk.com/forum/viewtopic...rque+lsa#75280
http://speedtalk.com/forum/viewtopic...t=torque#65739
Tim Smith
  #15
Old Dec 30th, 07, 01:28 PM
Who in the heck is this Harold that I keep hearing about???
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: cam for torque....110 or 112 LSA?????
Location
Location
First Name
Human Verification
