| Team Camaro Tech Current Topic: 67 Glass in 68 Doors??? | ||
| Body Shop Paint & Body Forum |
Can I put the glass and vent window from a 67 into a 68 door shell? I found a pair of 68 doors to replace my less than mint 67 doors. I don't have the car with me at this time so I can't compair them.
Thanks for you help. Shawn 67 RS Conv. |
| Sponsored Links | ||
Advertisement | ||
Not sure but something else to consider is that a 67 door panel doesn't go over the top of the door such as a 68 and 69 do. So if you can get the window to fit the door panels won't work unless you use a 68 or 69 type then it won't match the rears. Just something to think about.
------------------ Sean James 67 camaro convertible 454 - 700r4 4:10 12 bolt 69 Firebird |
Its amazing how much you forget when you don't have the car nearbye. I'm in PA and the car is stored in OH 500 miles away. I guess the only thing they share in common is the door skin and door handles.
Thanks for answering my brainfade question. Shawn |
No, there is a extra braceing inside the 67 door for the wing window.
------------------ 67 Camaro SS Conv. 70 Challenger R/T Conv. |
Another problem attaching '68 doors to '67..
The '67 uses 3 bolt hinges..the '68 uses 4 bolt hinges... You;d need to do some welding/body work, etc.... I though about this too...chaning to '68 doors, to get rid of the freakin' vent windows... but after much investigation found it;s not worth the hassle... David |
| Sponsored Links | |
Advertisement | |
