Vintage Air Install on a 69 - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Thread Tools Display Modes
Old Jan 6th, 08, 04:52 PM
windycity1 windycity1 is offline
Dante'
Default Vintage Air Install on a 69
I have a 69 Camaro that was an original factory air vehicle. When ordering vintage air how much of the factory system is used. I there somthing in the kit that replaces the briefcase on the firewall?
69 Camaro SS
Old Jan 6th, 08, 05:05 PM
Pro-Street69Camaro468 Pro-Street69Camaro468 is offline
Dave C
Default Re: Vintage Air Install on a 69
My car is non factory air. I got my stuff from DSE check them out they have a lot of cool stuff in there site.
Old Jan 6th, 08, 05:06 PM
67motorcat 67motorcat is offline
Steve O.
just about the only parts used from the original system will be the dash control panel and the original air vents in the dash.The suitcase with be replaced with a low profile panel with various holes for lines,hoses,etc.The entire Vintage Air unit fits inside the car....If I were you and you have a factory AC car I would try to restore and keep the original unit.The VA units are nice but not as good as the OEM when working correctly.
67' Vert RS Tremec TKO- Eaton 3:55- 350 cu.- L98 heads-Vintage Air- Torque Thrust-BFG.g-force 4-wheel disc.
Old Jan 6th, 08, 07:10 PM
BA. BA. is offline
Allan
yup, the briefcase goes away and the replacement unit fits under the dash.
at the firewall you'll have 4 new holes to create for the lines to the unit. you'll also be converted over to the newer refridgerant so the old compressor will not be used either.
The VA unit offers new control panel if you want to use it.
you'll get new ducting to mate your dash vents to the new unit.
69 RS - LS7, T56, Currie, DSE, ATS, Vintage Air, Wilwood
Original floor/trunk. Under construction.
Build Thread, Other Pics
Old Jan 6th, 08, 07:55 PM
Havin' Fun's Avatar
Havin' Fun Havin' Fun is offline
Tim
I thought VA did "original" system component restorations?
Old Jan 6th, 08, 08:19 PM
madmax87's Avatar
madmax87 madmax87 is offline
I'm not sure about a factory air car, but I'm in the process of installing VA Gen IV on my 69 and the heater block off plate has another plate that attaches to it (4 holes) so there are no new holes to drill. They supply everything. You will use your control panel but they give you all new hardware to hook up to it. You will not use the cables. I'm going to use the universal 3 knob controller in its place. I'm in the process of making a mounting panel to replace the factory panel. Will post pics later.
Dennis
69 Z/28. 302DZ, Autogear M22, Red w/black stripes.
69 Camaro, ZZ4, 700R4, 8.5 3:42 posi, X11
70 Nova SS 396, 4sp, 3:55 12 bolt
Old Jan 6th, 08, 10:48 PM
ProdigyCustoms ProdigyCustoms is offline
Frank
We sell a ton of these systems, many to board members here. The factory A / C kit will feature a block plate similar to the NON A / C cars, but will fit the different firewall openings. You will be trashing every single piece of the old system except the controler in the dash and A / C vents. All the cables, hoses, ducts, defroster ducts, inside heater core box, outside evaporator box, old compressor, condensor are all gone.
The new Gen IV systems blows away any other "Camaro A / C systems" out there.
If you have any questions, feel free to call
four zero seven 832 1752
Old Jan 7th, 08, 08:12 AM
tgifford5 tgifford5 is offline
Team Member
Ted
Does it even beat out the CAA systems? And why? Since I know that you sell both. Adding aftermarket a/c to my factory a/c 69 in the near future. Thanks.
Old Jan 7th, 08, 08:37 AM
hhott71 hhott71 is offline
Tom
No, the Classic Auto Air kit uses replaceable parts on its HVAC system incase a part breaks for some reason. VA is a sealed case that needs returned to VA for service. The Clssic Auto air system uses seperate coils for the AC and the heater, VA uses a one peice combined coil.
You can keep the OE compressor and Condenser if so desired too, Many many options to choose from.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Old Jan 7th, 08, 01:04 PM
Frank
Well, first and Foremost, I have never replaced a evaporator except for collision repair, and only have to replace heater cores after 40 years and no antifreeze, so the serviceability is not a issue. Antifreeze has come a long way, and lets face it, we are going to maintain out babies. And in 40 years if it needs a new evaporator, VA will change it for a couple hundred bucks, if it needs a heater core, more like a hundred bucks.
I do sell both brands, I actually have 3 brands. Classic Air is good stuff no doubt. For us right now, we are using Vintage Air in all our first gen Camaro builds. I could go off one many attributes we could use from the "sales" guide. Bottom line, The Gen IV was designed for the OEM for Ford when they hired Vintage Air to design the A/C for the then new Ford GT (GT40). The Gen IV is what they ended up with. Long story short, if it is good enough for a $200K car, it is good enough for your old hot rod.
I just did a install of a Gen IV and put a thermometer in the vent, 42 degrees! And maintained the cabin in Florida 90 degree day just fine. We actually had to turn the blower down one notch off high as it got to cold at one point. We have most likely installed a hundred aftermarket A/C systems, including Vintage Air, Classic Air, and Hot Rod Air. I never turned down the blower on a unit until now!
As a parts seller, we have a distinct advantage over manufacturers and most parts dealers and can give opinions from experience. We build a lot of cars. We have a even dozen Camaros right now, amount a dozen other non Camaro projects. We do not have to quote sales jargon from manufacturers because it is the company we work for. We have multiple brands to sell you. Because I have 3 products available, I give unbias NON financially motivated opinions as I can make money no matter which brand you buy from us. I just state my personal experiences, just the facts.
  #11
Old Jan 9th, 08, 06:46 PM
1969SSBB 1969SSBB is offline
I am installing a Vintage Air Gen IV in my factory AC 69 I am restoring. I am also going from SB to BB (454). My question concerns wiring harnesses for underhood. I am going to purchase a Factory Fit and am wondering what harness I need and maybe what mods may need to be done to it. The car is an Auto with console and lights in the dash and I will be using an internally reg. alternator (possibly passenger side). Any suggestions would be a great help. Thanks!
  #12
Old Jan 10th, 08, 08:36 PM
Frank
Are you doing a complete new harness? If so we just need to set you up with a Classic Update and you will have all the additional circuits you need.
You may want to call me to discuss
  #13
Old Jan 13th, 08, 04:23 PM
RJBaileyrn's Avatar
RJBaileyrn RJBaileyrn is offline
RJ
Is the Vintage Air setup something a person can istall himself, or do you have to pay to have it done. If installed by the seller, what would be average total cost, parts and installation? Thanks much,
RJ
69 RS coupe, 4.11 Richmond gears, Muncie 4-speed, Dart SHP 406, 11:1, 4340 H-beam rods and crank. SRP forged pistons, Milodon 7-qt pan, Dart single plane and 215cc Pro1 alum heads, Comp XR300HR cam and roller rockers, Howard hydraulic roller lifters, Hooker 1 3/4" Super Comps, Quick Fuel 750 carb
  #14
Old Jan 13th, 08, 05:25 PM
Frank
RJ, I have sold a lot of units that are owner installed. You will want to have a A/C shop vacuum and charge the system, but other then that with normal hand tools and average mechanical skills you should be able to do it. Your cost with be right at $1300 for the system, and figure about $100 to a A/C shop for the vacuum and freon charge
  #15
Old Jan 13th, 08, 05:52 PM
JimM JimM is offline
Jim
As there are a bunch of new guys in this thread, I thought it worth mentioning that Frank has been a long time poster here, long before we had sponsorships, and he has helped many. I've taken his advice more than once, and I've done business with him too. Itsa priveledge to have a pro like Frank here.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Heating & Cooling      Current Topic: Vintage Air Install on a 69
Location
Location
First Name
Human Verification
