2.08 Intake on a 400 .030 Overbore - Team Camaro Tech
Old Jan 17th, 08, 10:44 AM
76' Bad Bird 76' Bad Bird is offline
Tech Team
Shannon
Question 2.08 Intake on a 400 .030 Overbore
Have a small block 400 thirty over with a set of Dart Pro 1's 2.08 intake and 1.60 Exaust Anyone forsee problems on a street strip car. Compression will be 11.3.
76'fire bird Trans Am Under total resto
Old Jan 17th, 08, 10:54 AM
Steve69SS396's Avatar
Steve69SS396 Steve69SS396 is offline
Steve
Default Re: 2.08 Intake on a 400 .030 Overbore
Don't quite understand your question. Are you asking if the valve size will cause a problem? Or maybe you are asking about piston to valve clearance?
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Total Seal rings, hand ported AFR 210 heads, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .660" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 8" converter
Old Jan 17th, 08, 11:00 AM
Tech Team
Shannon
Engine runs but is set up with a 1050 carb and a drag cam. Wondering about the valve size. Every thing I find puts it borderline.Just looking for clarification.Thanks for cathing that slip up.
Old Jan 17th, 08, 11:18 AM
Steve
Still don't quite understand, but I'm running AFR 210 heads on my 355 with 2.08" valves. That valve size shouldn't be a problem in your 406.
Old Jan 17th, 08, 02:27 PM
DOUG G DOUG G is online now
RedЯuM
2.08's should be ok... but that 1050 carb and only 11.3:1 ? I see the carb as an issue.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Jan 17th, 08, 02:55 PM
HarleyD67's Avatar
HarleyD67 HarleyD67 is offline
Harley D
Ditto on the carb issue. I can tell you for a fact that 2.08's fit a std 400 bore. I've got AFR210's on my 427. Now with Steve's combo I would have some clearance concerns.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.7281/4-11.83@115.59
firstgens.com
Old Jan 17th, 08, 04:05 PM
Steve
They bolted right on without any clearance problem. Been doing fine for 8 years now. Here is how it performs:
My '69 Camaro running 10.47 @ 129MPH with a 1.52 sixty foot at Sacramento Raceway. 355 SBC with a 150 shot.
Old Jan 17th, 08, 04:25 PM
GOSFAST GOSFAST is offline
That's actually a good combo. (Have made some decent power with those "Pro-Ones" also!)
On a recent build (with a "Dart" block) 406" 11:1, Pro-Topline 235's (2.080's), a "small" solid roller, and a "Victor" with a 4500 and 2.000" primaries unit cam off the dyno @ 610 HP.
Is in a "street/strip" ride now, 3600#+, and runs 10.70's @ 124 MPH. All on 93 octane!
Thanks, Gary in N.Y.
P.S. In all honesty, a 2.080" valve or larger actually hurts the overall performance on a 4.000" SB (either +.030" or +.060"). The larger valves end up experiencing flow issues with the cylinder walls. We just delivered a 383" SB with 550+ HP using some 2.020's (older Brownfields) and 93 octane also! These are all slightly "higher-end" solid-roller units, not "budget-builds"!
