Minor Problem With Camaro - I Should Have Known Better - Team Camaro Tech
Bench Racing Stories, cruising and more.
Old Jan 21st, 08, 04:33 PM
DougP's Avatar
DougP DougP is offline
Doug
Default Minor Problem With Camaro - I Should Have Known Better
So the car has been sitting in the garage since October and I have not had a chance to start it up and drive it around since then. So I decide to install my electric fan kit.
I remove fan, and mount the electric fan to the radiator.
I drain the radiator and install the new sending unit and wiring.
I wire up the relay and the rest of the electrical connections.
So after all that, and having the car sit for several months without starting it, I crank it over a few times for about 15-20 seconds and the car starts up and sounds healthy. After a few seconds my buddy is giving me the universal sign to shut it down. Seems that the cheap fuel filter that I was going to replace was squirting gas all over the place.
I used that filter because I had it laying around the garage when we put the motor in. Seems I got an attack of the "lazys" and didn't change from that crappy filter to a better one --- Oh well, easy fix, but it just goes to show you -- I should have known better
==Doug
Former 69 Camaro owner
Former 70 Pro Street Nova owner
Former 2nd 69 Camaro owner (pics of resto project)
Old Jan 21st, 08, 04:47 PM
Geezer Geezer is offline
Default Re: Minor Problem With Camaro - I Should Have Known Better
It looks like the sending unit wire is going to get burnt laying on the header. You can get 90* spade connectors to keep the wires away.
Ron
The “Junk Yard Dog
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Old Jan 21st, 08, 05:03 PM
DougP's Avatar
Doug
There's actually about 1/4" space between the header and wire, but yea I agree with the 90* spade connectors or some type of asbestos cover.
==Doug
Old Jan 21st, 08, 06:04 PM
Pro-Street69Camaro468 Pro-Street69Camaro468 is offline
Dave C
Doug, Have you ever heard that you not supposed to put teflon tape on the threads that it will cause a bad signal. How true is this and also your not supposed to run the sending unit wire next to an power wires how true is this.
Old Jan 21st, 08, 07:34 PM
DougP's Avatar
Doug
Dave -- its a Painless wiring kit and the instructions were very specific about not using teflon tape on the sending unit because you wouldn't get a good signal. As far as the wires to the sending unit, one wire comes from the the relay box (see picture) and the other wire is a ground. Once I replace the fuel filter, I'll fire the car back up and see if the fan turns on when the motor warms up.
==Doug
