Fuse in place of Fusible Link? Is it ok? - Team Camaro Tech
Thread Tools Display Modes
Old Jan 25th, 08, 12:35 PM
68RS-SS 68RS-SS is offline
Bill
Default Fuse in place of Fusible Link? Is it ok?
Is there any problem with using a fuse vs. a fusible link on the wire that transports power from batterty to rest of car? If not, what size fuse would be equivalent/appropriate for this application?
Thank you!
Old Jan 25th, 08, 02:51 PM
onovakind67 onovakind67 is offline
Default Re: Fuse in place of Fusible Link? Is it ok?
How many amps does the circuit draw? What is the amp rating of the wires you are trying to protect?
Old Jan 25th, 08, 04:29 PM
dnult dnult is offline
Technically putting a fuse in place of a fusable link would be safe. However, fusable links are much more forgiving than a fuse. Why do you want to do this? Fusable links are cheap and work well for high current power sources.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Jan 25th, 08, 05:07 PM
Chilli Chilli is offline
Tech Team
Is a fusable link at one end of the wire or in the middle on the main power wire to the car?
I hope you don't mind me jumping on board the thread too.
Old Jan 25th, 08, 05:27 PM
The fusible link is typically at the highest potential in the wire, which would be the end of the wire closest to the power source.
Old Jan 25th, 08, 05:30 PM
Tech Team
thanks
Old Jan 25th, 08, 07:44 PM
JimM JimM is offline
Jim
The can be bought, try madelectrical.com
Old Jan 25th, 08, 07:58 PM
77wolf10.85's Avatar
77wolf10.85 77wolf10.85 is offline
Tim
They also have them at NAPA parts stores. I've had to stick fuses instead of links at least a few times to get junk running. Like dnult said though, the link is sloblow. I think they look better than a fuseholder too.
Tim Smith
Old Jan 26th, 08, 06:32 AM
Bill
Originally Posted by 77wolf10.85 View Post
. . Like dnult said though, the link is sloblow. I think they look better than a fuseholder too.
That's the info. I was needing - thanks all.
Old Jan 26th, 08, 05:06 PM
Make sure to put those fusable links in a place where they can melt down without starting a fire. Never bundle them together or tape them up with other wires. Let them hang free. As others have said, near the power source is where they belong.
Dave
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: Fuse in place of Fusible Link? Is it ok?
Human Verification
