headliner to be the death of me!!!! - Team Camaro Tech
Old Jan 26th, 08, 01:30 PM
Mochatea396 Mochatea396 is offline
Tech Team
Default headliner to be the death of me!!!!
Is it normal for installing the bows in the headliner to take about an hour each??? They slide about 1/8 a time then twist the material and have to back it out 1/16 to get the twist out or it won't go any furthur. And this center rod (the one with no material grabbing bends on it?), does this attatch to anything or just float loose in the pocket? Thanks again guys.
Old Jan 26th, 08, 02:01 PM
ascamaro ascamaro is offline
Tech Team
Default Re: headliner to be the death of me!!!!
the easiest way to put the rods in is to sand the rods first which makes them slide right in. as for the the center rod, if you look on the roof brace you will see little metal triangle tabs which the rod attatches to. GOOD LUCK
Get it, Got it, Good
Old Jan 26th, 08, 02:03 PM
69TAPoser 69TAPoser is offline
Phil
and after you sand them, spray them with furniture polish.
phil
My '69 Firebird Build Site
My '73 Camaro Build Site
You Located in New England? Check out our Yahoo! Musclecar Group.
Old Jan 26th, 08, 04:04 PM
Badbird's Avatar
Badbird Badbird is offline
Banned
Ron
This is good advice!.....I'll be installing a headliner this spring/summer and I'll sand and polish my rod before I insert!
Old Jan 26th, 08, 04:29 PM
Tech Team
Thanks again guys, I sanded the rust down, I didn't have any furnature polish handy so I just went with it with the sanded bows. Sanding them did help a bit, they still are a real slow go. Just make sure it doesn't twist and bunch up the material as you go, once it bunches up, it won't go any further until you undo the knoted material. The polish probably would have helped even more. I noticed someone posted that they heated the clips on the roof so the bows would snap in easier, do you think a little white grease might help or the grease might slowly deteriorate the plastic clips? Well after finally getting the bows in their pockets and the length of the pockets trimmed down, I think we'll call it a day and leave the installation "attempt" until tomorrow. Thanks again.
Old Jan 26th, 08, 04:49 PM
rare4k rare4k is offline
phil
if you have another person, let them push on the rod and you work the material both hands up off the lip of the rod, it took us about 10 min with two people and cleaned the rod on a wire wheel.
Old Jan 26th, 08, 06:17 PM
mb302rs's Avatar
mb302rs mb302rs is offline
Mike B
I would not use white grease ,it may wick through the headliner when it gets hot this summer.
Mike B
69 RS Z28 X33
69 SS (badged) X11
68 Jane in pieces
68 RS/SS BB major project
69 firebird 400 project (Currently under construction ) Pics below
Still wingless.
http://rides.webshots.com/album/567938443oGCqFi?start=0
Old Jan 26th, 08, 06:40 PM
tony -Di tony -Di is offline
Tony
hey my 2 cents i cleaned primed and painted my rods because they where pretty rusted i allso installed isulation in before i installed the linner
Old Jan 26th, 08, 06:45 PM
jay'srs/ss's Avatar
jay'srs/ss jay'srs/ss is offline
Jason
I was watching the latest episode of MuscleCar today on Spike. They had a guy come in and install a headliner in the Lemans they're doing, very similar to a 1st gen F Bodies headliner with bows and all. He said to use a light coating of WD40 to get the bows to slip through the material in the holes easier.
My Cars:
67 Camaro RS/SS350
70 Lemans Sport 350 w/ 48k Original Miles!!! SOLD!!!
02 Corvette Z06 SOLD!!!
88 Camaro IROC-Z SOLD!!!
67 Ford F100 SOLD!!!
Old Jan 27th, 08, 07:07 AM
Phil
I'd still rather use the furniture wax vs. a grease/oil like wd40. It just seems less risky and the spray furniture wax works perfect, disappears, and won't seep into the fabric.
Phil
Old Jan 27th, 08, 06:50 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Mike
I didnt have to use anything to get mine to slide in. It takes some patience to get them in there. There is like a cloth loop sewn in that they slide into. I found that I had to trim this on the ends of each side to keep the headliner from puckering on the sides.
I would not use grease, WD40 or anything that is going to stain the headliner!!
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig miles
1979 Camaro Z/28 36K orig miles
1984 Camaro z/28 LG4 auto
