New U-joint stiff, normal? - Team Camaro Tech
Thread Tools Display Modes
Old Jan 27th, 08, 05:23 PM
tgifford5 tgifford5 is offline
Team Member
Ted
Default New U-joint stiff, normal?
I replaced the rear U-joint when I install my 12 bolt. The front U-joint rotates and moves around freely. But the new one seems very tight. The cups that will mount in the yoke to the pumpkin of course turn with ease. But the part that is mounted in the yoke with the clips rotates very stiff. The cups look like they are right up against the clips. Is this normal for a new U-joint to be so stiff?
Old Jan 27th, 08, 06:08 PM
Milan Milan is offline
Default Re: New U-joint stiff, normal?
They can be stiff. I used to seat the cups by tapping the yoke so as to seat the cups and clips into the yoke. Its difficult to explain... I would support the joint between two blocks of wood on the horizontal sides of the joint then I would tap on the upper most part of the yoke seating the cup and clip into the yoke, then do the opposite side cup. then seat the other part of the yoke inbetween the two blocks and repeat the process. That usually freed things up nice..
Milan
67 Blown Alcohol Camaro "The Combat Rat" 8-71 and E-85/71 BB SS Chevelle "cheap street" (clone) 12.871 @ 107.59 w/1.915 60' and spinning /2002 35th anniv SS Z28 conv./74 454 El Camino .
Old Jan 27th, 08, 06:27 PM
dnult dnult is offline
Examine how the caps meet up with the core real closely. It's not uncommon to get a needle wedged between the end of the cap and the core. As a result, one cap won't seat fully onto the core. If both caps are seated, you're probably ok.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Jan 27th, 08, 07:26 PM
Team Member
Ted
The caps seem to both be seated evenly, no gaps or anything unusual. Just stiff. I previously installed the shaft but felt uneasy about the stiffness. I have not run it either as it is still to snowy out. I want my first ride with the new 12 bolt posi to be a good one. Not one where I brak down because I did something stupid or prevented.
Old Jan 27th, 08, 07:27 PM
Team Member
Ted
The caps seem to both be seated evenly, no gaps or anything unusual. Just stiff. I previously installed the shaft but felt uneasy about the stiffness. I have not run it either as it is still to snowy out. I want my first ride with the new 12 bolt posi to be a good one. Not one where I break down because I did something stupid or could have prevented.
Old Jan 27th, 08, 08:05 PM
zdld17 zdld17 is offline
Don
Could you have dropped one needle roller into the end of the cup?
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Jan 27th, 08, 08:11 PM
Farm Boy's Avatar
Farm Boy Farm Boy is offline
Steve
Try spreading the driveline yoke a bit with a punch and a large hammer.
Steve
1967 Camaro
I drove it for the first time in 1972 when I was 15.
1956 Bel Air Sport Coupe
Better looking than a '56 Ford or Plymouth.
Old Jan 28th, 08, 06:59 AM
Team Member
Ted
I had read where someone had done that. So prior to installing I used a little grease on the bearings to hold them in place. Also if I had done that wouldn't the bearing cup not sit flush?
Old Jan 28th, 08, 07:01 AM
Team Member
Ted
Milan
I'll try that and see if it loosens at all.
Old Jan 28th, 08, 08:59 AM
Matt M. Matt M. is offline
Team Member
Matt
I just went through the same thing. I installed new u-joints and two of the three pivots were stiff.
I did a little research and read that new u-joints should NOT be stiff. To fix the problem I pulled off the c-clips and tapped the caps back. I used a hammer and flat punch. I didn’t have to push them back very much—I just gave them a few light taps on each side.
I think I had pushed the caps too far in and they were binding. I pushed them in that far so I could get the c-clips in.
The light taps on each cap freed up both stiff joints. The c-clips barely catch, but they are in there. Make sure you take the c-clips out before you tap the caps back. If you don’t pull the clips, the caps won’t move.
  #11
Old Jan 28th, 08, 10:34 AM
Team Member
Ted
I did a little research and read that new u-joints should NOT be stiff. To fix the problem I pulled off the c-clips and tapped the caps back. I used a hammer and flat punch. I didnít have to push them back very muchóI just gave them a few light taps on each side.
The light taps on each cap freed up both stiff joints. The c-clips barely catch, but they are in there. Make sure you take the c-clips out before you tap the caps back. If you donít pull the clips, the caps wonít move.
It seems as though the caps are right up against the clips, but I will give it a try. And hope the clips go back in.
  #12
Old Jan 28th, 08, 12:34 PM
mbrekke's Avatar
mbrekke mbrekke is offline
Mark
You can leave the clips in and press, or pound with something suitable, the caps that are in the other 'plane' in a way that seats the caps in the yoke firmly against the clips. The center of the clip may bulge out just a little. Kind of hard to explain like someone else stated. It's not difficult though. Then tap the yoke lightly with a hammer where the caps are seated. They will loosen right up.
Mark
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
http://www.camaros.net/forums/member.php?u=3230
  #13
Old Jan 28th, 08, 04:18 PM
Team Member
Ted
Mark
Did that as soon as I got home. I used a 2x4 against each cup in the other plane and gave them a rap with the Ford tool in each direction to push outward on the cups. Still seemed to be a little tight so then gave each cup a little rap using a punch at the top and bottom of both tight cups and everything loosened right up. Now that that is fixed. On to the next project! Thanks guys!
  #14
Old Jan 29th, 08, 02:24 PM
Fred Ficarra Fred Ficarra is offline
Fred
Don't ya love stuff like this?
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) with Coan 8" converter, GV-OD, 8 track still on console and best et 10.495, 128.79mph 1.428 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers & 3" full exhaust with X pipe.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
http://ss427.net/
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: New U-joint stiff, normal?
Location
Location
First Name
Human Verification
