| Team Camaro Tech Current Topic: 15x8 Corvette Rally wheel info needed | ||
Wheels & Tires What fits what?
I am thinking about buying a set of 15x8 Corvette rally wheels that are on a 1972 Corvette and I would like to know if the wheels will rub or if there is any type of clearance issue with these wheels. I would be installing the wheels on a 69 camaro. Also If the wheels will work without any issues I would like to put BF Goodrich T/A radials tires on the wheels and would like to know what the correct size would be for that size wheel. Any info would be great. Thanks
| Sponsored Links | ||
Advertisement | ||
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags My Cars |
Backspacing is wrong for a 69. Had them on mine, and they rub the outer lip on the rear fender. The front worked OK with a 225/70 if it's not lowered.
GM 15x8s used on Vettes have 4" backspace, which really is not enough up front on a 69. It's not really enough in the back either, but they work better there than up front on a 69.
Eric 69 'vert project big block/TKO 600 RR 68 'vert driver RS clone -- gone! |
I ran 235/60 rear and 225/60 front on my 8in ralleys and it fit well. The owner before me ran 255's in back and it rubbed the inner well, the marks are still there.
67 vett had a 15x7 witha back space that uses a deep ring that looks like a 8 inch wheel in the front. Ran them for year on 67 and 68's with no problems and a 225 60 15 tire.
Not sure what the back space is though?
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn....... Then, you have enough horsepower." -Mark Donahue My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805 |
I run 225/50/15 up front and 265/50/15's in rear on my 15X8" corvette ralley's. I do have issues of rubbing in back on outer lip, but I corrected with airshocks. No issues up front.
I plan on switching tire sizes to match what ever BFG Radial TA I can get. I would like to swap someone two of my ralley's for 4.5 or more back space for the rear.
Mike 68 RS Convertible 327-L30/TH350/12 Bolt 3.73 |
I've bought mine at http://www.carid.com/custom-wheels.html and don't have troubles with them. Swap is not a bad thing at all, but as for wheels, I prefer to buy new - just my thoughts.
| Sponsored Links | |
Advertisement | |
