Loose bearing race in front hub - Team Camaro Tech
Old Jan 30th, 08, 01:42 PM
Motown 454 Motown 454 is offline
Wayne
Default Loose bearing race in front hub
I have a set of 69 Camaro drum front hubs with a loose bearing race in one of them its the outer race. Is the hub junk or can It be saved? Its going to be used in a C6 Z51 brake swap. It is already machined, the machinest did the work and then told me about it. I need it to get the car home from the body shop anyway. It will be trailered,any help would be appreciated.
Wayne
Old Jan 30th, 08, 03:15 PM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: Loose bearing race in front hub
Drum brake hubs are readily available. I would not waste time in fixing the old one, but it can be sleeved by a good machinist to fit the race.
Hubs are on most every GM intermediate car, those with a 4.75 bolt pattern. Novas, Chevelles, Skylarks, Tempest, etc.
Full size is 5.00 inch bolt pattern.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Feb 1st, 08, 07:29 PM
davidpozzi davidpozzi is offline
David Pozzi
I would look for a replacement hub, they are not reproduced as far as I know. The machinest may be able to center punch it to hold the race for a while, but long term you need a better fix than that. Locktite sells a product that can hold the race pretty well, but I'd look for another hub.
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Feb 1st, 08, 08:08 PM
67pat 67pat is offline
Pat
How loose are we talking about...does it just spin freely with one finger or does it fit kind of snug but can be spun with a little effort?
Old Feb 2nd, 08, 07:47 AM
pdq67 pdq67 is offline
Banned
If it doesn't spin like a top, I'd clean everything GOOD using BrakeClean and let dry and get some JBWeld and put a daub all around in the hub.
Install w/o touching anything w/ my fingers that always seem to have a natural oil on them. I don't want any oily fingerprints on anything to upset the JBWeld is all...
Let her set up over a couple a days and go!!
JBWeld does some things other stuff just doesn't seem to, imho..
pdq67
Old Feb 2nd, 08, 06:08 PM
Pat
Old school shop I used to work at that happened occasionally.The fix was to take a punch or small chisel and score the inside walls of the hub where the race seats. Drive the race in like you would normally,the scoring gave something for the race to "bite" for lack of a better term...Worked every time!
Old Feb 3rd, 08, 11:45 AM
Wayne
Thank you guys I have a trade school near me thye think they can knurke it to fix it . I will just use it to move the car around while Im working on it. then find a replacement .
Thanks Again Wayne
