where to put a cd/stereo hidden - Team Camaro Tech
Old Jan 31st, 08, 07:27 PM
texascamaro texascamaro is offline
steve
Default where to put a cd/stereo hidden
any suggestions as to where i can hide a modern stereo and cd player in my 67 vert...some pics of any ideas would be nice....i was thinking the glove box with a remote controlled stereo, but i would like to see some other ideas from all of these creative camaro guys...thanks
Old Jan 31st, 08, 07:30 PM
go2fast go2fast is offline
Jim
Default Re: where to put a cd/stereo hidden
That's where mine is with an infrared repeater so I can control it without opening the door. Works great. I used an under dash mount upside down. You'll have to cut a hole in the back of the liner, but they are readily available and cheap.
Old Jan 31st, 08, 07:35 PM
steve
is the stereo upside down in the box and is the mount on top or bottm of the box...by the way...i bought this car from a guy in Tewskbury,Ma...you anywhere close
Old Jan 31st, 08, 08:46 PM
.gearhead.'s Avatar
.gearhead. .gearhead. is offline
Jim
They make radio/changers that mount in the trunk and all you need up front is a remote. That was the one I was going to buy, until I realized I'd rather listen to the engine.
Jim
1968 Camaro
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
Old Jan 31st, 08, 09:18 PM
larry A/SA larry A/SA is offline
larry
I have a 67 camaro and put it under the pass side seat. Receiver that is.cd is in the trunk under the spare tire. everything looks stock and neet.
Larry
Old Jan 31st, 08, 10:15 PM
Old Man Old Man is offline
Mark
I mounted mine in the glove box also. As was previously stated you will have to cut out the back of the box to fit the unit in. I put the cd player in the mount bracket and put it all the way to the back of the glove box then traced around the mount, cut out the back and slid the cd player in enought to get the door closed and then marked a line across the face of the mount and down both sides and the removed the player from the mount. The mounts have tabs on all 4 sides that can be bent. I located 2 tabs on the bottom that I could use and bent them straight down and then marked box where the tabs would go thru and made 2 slits in the bottom of the box. Slid the mount in, bent the tabs up to lock the mount down and slid the player in. You can't see it with the door closed but my IR remote won't work with the door closed so I just turn it on, close the door and press the gas.
Glacier Blue/Dover White 69 SB SS Restoclone.
http://img513.imageshack.us/my.php?image=img0071xe9.jpg
99 Trans Am...my toy
http://img519.imageshack.us/img519/3...perdrag6kn.jpg
Old Feb 1st, 08, 05:32 AM
blue ss blue ss is offline
I use a conversion, looks like stock but plays am, fm, Ipod, It works great. plenty of them to pick from.
Old Feb 2nd, 08, 06:28 AM
tomg tomg is offline
Tom
Old Man, can you post a picture of your set up you have? Sounds like what I'm interested in doing too.
Tom
67 RS B/N Yellow
Old Feb 2nd, 08, 08:57 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Tom at the bottom of my list of pics in my Interior folder are pics of my Pioneer setup with 6cd changer hanging under the glove box. I could put it in the trunk but then have to get out of the car to change the cartridge. I left both in and under the glove box.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Feb 2nd, 08, 09:59 AM
Microgiant Microgiant is offline
Timothy
Here is an idea. I dont really even listen to CDs anymore. So im wiring my trunk with a 4-speaker amp, I will then run a plug into the glovebox for a MP3 player. Simple cheap and does all I need it to. you can even get a MP3 with a built in radio if you want to listen to am/fm.
My 69 RS/SS 396 Project - www.easymoney69.com
"I may be dumb but I aint stupid"
Old Feb 2nd, 08, 03:29 PM
Mark
Not sure how much these will help, I didn't want anything showing from the outside or while sitting in the car.
Old Feb 2nd, 08, 06:27 PM
Tom
Old Man, I like that, it looks simple too, are you also referring the mount bracket that comes with the stereo or one that you had to buy seperately? I notice you also say your remote won't work with the door closed, I wonder if one is made with radio frequency and not IR, it would work with the door closed then..........
Tom
67 RS B/N Yellow
Old Feb 2nd, 08, 09:29 PM
Mark
I just used the mount bracket and face plate that came with it. I would pull the cd and show you but I can't find those damn little DIN tools to get it out. My complete system is clean and simple, I like it that way and it sounds ok too. The Pioneer CD player has a 22 watt per channel mosfet amp which is enough to power the 2ea 4" 2 way dash speakers and the 2ea 6" X 9" 3 way speakers in back which are hidden by the mesh package tray. I did the install for a total of $225.00, cheap and it sounds decent which works for me.
Old Feb 3rd, 08, 07:35 PM
Brentmc's Avatar
Brentmc Brentmc is offline
B...t
Here's mine--$12 under-dash mount case and $50 Pioneer MP3/CD Player (used) with remote. Works perfect.
Old Feb 3rd, 08, 07:37 PM
Brentmc's Avatar
B...t
Same hardware but someone else's pics:
