Sponsors Sales & Specials
Old Feb 1st, 08, 07:39 AM
CS3 Auto's Avatar
CS3 Auto CS3 Auto is offline
Creight
Default February Sale Listing
February Sale List
AFM13000 - AFM SBC Rotating Assembly; 350 C.I.; 3.480 Stroke; 5.700 Rod; 9.8:1 Compression $1739.99 Sale $1519.99
AFM13001 - AFM SBC Rotating Assembly; 350 C.I.; 3.480 Stroke; 6.000 Rod; 9.8:1 Compression $1739.99 Sale $1519.99
AFM13002 - AFM SBC Rotating Assembly; 383 C.I.; 3.750 Stroke; 6.000 Rod; 10.5:1 Compression $1779.99 Sale $1559.99
CRO73601-16 - Crower SBC Stainless Steel Rollerized Rocker arms; 1.5 Ratio; 7/16 stud $439.99 Sale $402.99
CRO73641-16 - Crower SBC Stainless Steel Rollerized Rocker arms; 1.6 Ratio; 7/16 stud $439.99 Sale $402.99
CVROP65582 - CVR SBC Billet Aluminum Prolube Oil Pump; 8-1/4 Inch Deep Oil Pan $282.99 Sale $259.99
CVROP65595 - CVR SBC Billet Aluminum Prolube Oil Pump; 9-1/2 Inch Deep Oil Pan $282.99 Sale $259.99
CVROP655CT - CVR SBC Billet Aluminum Prolube Oil Pump; Circle Track; 7 Inch Deep Oil Pan $275.99 sale $249.99
CVROP655SP - CVR SBC Billet Aluminum Prolube Oil Pump; Stock Sump $282.99 sale $259.99
DEM5402020GC - Demon Mighty Demon Carburetor; Gen. Comp. 750 CFM; Annular Boosters $569.99 sale $505.99
DEM5423020GC - Demon Mighty Demon Carburetor; Gen. Comp. 800 CFM; Annular Boosters $569.99 sale $527.99
DURCHP-12 - Dura-Bond BBC 1967-99 High Performance Cam Bearing Kit $29.99 sale $22.99
DURCHP-12T - Dura-Bond BBC 1967-99 High Performance Cam Bearing Kit; Coated $46.99 sale $42.99
DURCHP-8 - Dura-Bond SBC 1964-99 High Performance Cam Bearing Kit $22.99 sale $18.99
DURCHP-8T - Dura-Bond SBC 1964-99 High Performance Cam Bearing Kit; Coated $48.99 sale $41.99
EAG12102 - Eagle Comp SBC 355 Rotating Assembly; 1 Pce Rear Seal; Dome Pistons; 5.70 Rods $1669.99 sale $1489.99
EAG12109 - Eagle Comp SBC 383 Rotating Assembly; 1 Pce Rear Seal; Dome Pistons; 5.70 Rods $1669.99 sale $1489.99
EAGCRS5700B3D - Eagle SBC ESP 3-D H-Beam Connecting Rod; Lg. Journal 327,350; 5.700 Rod Length $406.99 sale $329.99
EAGCRS6000B3D - Eagle SBC ESP 3-D H-Beam Connecting Rod; Lg. Journal, +.300 $406.99 sale $329.99
EAGCRS6000SLW - Eagle SBC ESP 3-D H-Beam Connecting Rod; Sm Journal, Ltwt; 6.000 Rod Length $586.99 sale $429.99
GMP12480002 - GM Performance Parts LT1/4 Hot Cam Kit $574.99 sale $556.99
HLY0-82751 - Holley 4150 Street HP 750 CFM Carburetor; Double Pumper $515.99 sale $415.99
HLY0-82750 - Holley 4150 Street HP 750 CFM Carburetor; Vacuum Secondaries $515.99 sale $399.99
HLY0-81570 - Holley Street Avenger 570 CFM Carburetor; Manual Choke $335.99 sale $269.99
HLY0-81670 - Holley Street Avenger 670 CFM Carburetor; Manual Choke $349.99 sale $285.99
HLY0-81770 - Holley Street Avenger 770 CFM Carburetor; Manual Choke $369.99 sale $307.99
HLY0-81870 - Holley Street Avenger 870 CFM Carburetor; Manual Choke $395.99 sale $319.99
LIZ50100 - LizardSkin Ceramic Insulation Coating $189.99 sale $149.99
LIZ50115 - LizardSkin Sound Control Coating $169.99 sale $129.99
LIZ50125 - LizardSkin Super Pro Spray Gun Kit $140.00 sale $129.99
MAHLS1340898F04 - Mahle LS1/LS6 Flat Top Pistons; 3.898 Bore; 3.622 Stroke; 6.098 Rod; 10.4:1 Comp $666.99 sale $566.99
MAHLS1314898F04 - Mahle LS1/LS6 Flat Top Pistons; 3.898 Bore; 3.622 Stroke; 6.125 Rod; 10.4:1 Comp $614.99 sale $529.99
MAHLS1340908F04 - Mahle LS1/LS6 Flat Top Pistons; 3.908 Bore; 3.622 Stroke; 6.098 Rod; 10.4:1 Comp $666.99 sale $566.99
MAHLS1340000F04 - Mahle LS1/LS6 Flat Top Pistons; 4.000 Bore; 3.622 Stroke; 6.098 Rod; 10.5:1 Comp $666.99 sale $566.99
MAHLS1340010F04 - Mahle LS1/LS6 Flat Top Pistons; 4.010 Bore; 3.622 Stroke; 6.098 Rod; 10.5:1 Comp $666.99 sale $566.99
MAHSBC250030D11 - Mahle SBC Dome Pistons; 4.030 Bore; 3.48/3.50 Stroke; 6.00 Rod; 13.0:1 Comp $680.99 sale $549.99
MAHSBC250030F05 - Mahle SBC Flat Top Pistons; 4.030 Bore; 3.48/3.50 Stroke; 6.00 Rod; 10.6:1 Comp $614.99 sale $499.99
MAHSBC125030F05 - Mahle SBC Flat Top Pistons; 4.030 Bore; 3.50 Stroke; 6.125 Rod; 10.6:1 Comp $614.99 sale $499.99
MAHSBC550040F05 - Mahle SBC Flat Top Pistons; 4.040 Bore; 3.48/3.50 Stroke; 5.70 Rod; 10.6:1 Comp $614.66 sale $519.99
MAHSBC250040F05 - Mahle SBC Flat Top Pistons; 4.040 Bore; 3.48/3.50 Stroke; 6.00 Rod; 10.6:1 Comp $614.99 sale $499.99
MCL64050B-00-07 - McLoed Street Twin Clutch Set; 1998-02 LS1 Camaro / Firebird $1459.99 sale $1279.99
MOR22167 - Moroso BBC Billet Aluminum Oil Pump; Gerotar Design; Inc Shaft And Mounting Stud $492.99 sale $459.99
MOR22163 - Moroso BBC Billet Aluminum Oil Pump; Spur Gear design; Fits 8 Inch Deep Oil Pans $431.99 sale $369.99
MOR22171 - Moroso SBC Billet Aluminum Oil Pump; Spur Gear design; Fits 8-1/4 Inch Deep Pans $369.99 sale $319.99
MOR74050 - Moroso Sealed Battery Box $104.99 sale $84.99
NXS20109-10 - Nitrous Express LT1/LS1 Gemini Twin Nitrous System $971.99 sale $871.99
PRP90032 - Professional Products PowerForce+ Harmonic Balancer; LS1 98-02 Camaro/Firebird $179.99 sale $159.99
PRP90033 - Professional Products PowerForce+ Harmonic Balancer; LS1/6 97-04 Vette $179.99 sale $159.99
PRP90030 - Professional Products PowerForce+ Harmonic Balancer; LT1 93-97 Camaro/Firebird $194.99 sale 175.99
PRP90000 - Professional Products PowerForce+ Harmonic Balancer; SBC 350; 6.75 Dia.; Int Bal $125.99 sale $115.99
PRP90002 - Professional Products PowerForce+ Harmonic Balancer; SBC 350; 8.00 Dia.; Int Bal $149.99 sale $134.99
SCA2-ICR6135 - Scat BBC 4340 Forged P/S I-Beam Connectors; bushed; 6.135 Length; 2.20 Journal $275.99 sale $239.99
SCA2-ICR5700-7/16 - Scat SBC 4340 Forged P/S I-Beam Connectors-bushed-5.70 Length-2.10 Journal-7/16b $305.99 sale $269.99
SCA2-ICR6000-7/16 - Scat SBC 4340 Forged P/S I-Beam Connectors-bushed-6.00 Length-2.10 Journal-7/16b $305.99 sale $269.99
SCA2-ICR5700-2000 - Scat SBC 4340 Forged P/S I-Beam Connectors; bushed; 5.70 Length; 2.00 Journal $275.99 sale $239.99
SCA2-ICR5700 - Scat SBC 4340 Forged P/S I-Beam Connectors; bushed; 5.70 Length; 2.10 Journal $235.99 sale $205.99
SCA2-ICR6000-2000 - Scat SBC 4340 Forged P/S I-Beam Connectors; bushed; 6.00 Length; 2.00 Journal $275.99 sale $239.99
SCA2-ICR6000 - Scat SBC 4340 Forged P/S I-Beam Connectors; bushed; 6.00 Length; 2.10 Journal $235.99 sale $205.99
SPE7490 - Spectre Magnabraid / Magna-Clamp Kit; Stainless With Blue / Red Clamps $52.99 sale $42.99
SPE7496 - Spectre Magnabraid / Magna-Clamp Kit; Stainless With Blue Clamps $52.99 sale $42.99
SPE7498 - Spectre Magnabraid / Magna-Clamp Kit; Stainless With Chome Clamps $52.99 sale $42.99
SPE7492 - Spectre Magnabraid / Magna-Clamp Kit; Stainless With Red Clamps $52.99 sale $42.99
SSBA123 - SSBC Standard Front Drum To Disc Front Kit; Non-Power; w/Spindles; 1967-69 $880.99 sale $729.99
SSBA123-1 - SSBC Standard Front Drum To Disc Kit; Power; w/Spindles; 1967-69 $1034.99 sale $859.99
http://www.cs3automotive.com
Creight Smith
CS3 Automotive
F-Body Performance Source
Web Site: http://www.cs3automotive.com
Email: sales@cs3automotive.com
Phone: 269.861.5849 (Please Leave Message)
[Click here for latest factory rebates and promotions]
