Chrome rocker trim on '68 Camaro - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Feb 7th, 08, 05:54 AM
greg1ontheedge greg1ontheedge is offline
Greg
Default Chrome rocker trim on '68 Camaro
Was the chrome trim along the rockers standard on '68s or perhaps an option? I've seen cars both ways but obviously after 40 years many could have removed. My car doesn't have the trim and I like the appearance so am thinking of putting it on. Thanks guys....
Old Feb 7th, 08, 07:00 AM
68CMRO 68CMRO is offline
Brad
Default Re: Chrome rocker trim on '68 Camaro
I've got a bare bones stock '68 and it came with the trim. I've always liked the trim on the top of the door running along the bottom of the window and have considered adding that to my car also, but didn't know if that came on special packages either.
1968 C10 SWB Torch Red
1968 Camaro, 250\Powerglide, all original (No, I'm not gonna drop a 350 in it!....Jeez!)
Old Feb 7th, 08, 07:13 AM
Greg
Thanks Brad. Yeah, I think my car was a plain jane originally but today it has the trim along the bottom of the windows and around the 'rain gutters?' over the tops of the doors. I don't know what that's correctly called. But I really like the look of the chrome running along the bottom edge of the body, wondered whether adding that would be weird or not. Of course, I've read many, many opinions that you do what you like on your car unless it's a true really original car.
Next I guess I'll ask if installing this chrome is something a non-body guy could do? I'm very capable but don't have body work tools and such.
Thanks again...
Old Feb 7th, 08, 08:12 AM
Rhino Rhino is offline
Ryan
I don't know if it was available by itself, although the trim is much more common on RS models.
I believe all you need to install the rocker trim is a drill. There are small holes in my rockers where there were pins holding the trim. There isn't any real "body work" required.
Old Feb 7th, 08, 08:34 AM
Greg
Thanks Ryan. I think you're right regarding installation, a series of holes where pins install that the chrome trim is attached. Shouldn't be much work or require any 'body work' just care and planning before drilling holes :-)
Old Feb 7th, 08, 08:52 AM
Vintage 68's Avatar
John
The Body Sill Mouldings were standard on all Base Camaros.
The 1968 Rally Sport had a different Sill Moulding than the base models or RPO-Z21 equiped cars.
The "Style Trim" option was available on any base Camaro as RPO-Z21 - it included the Bright Front and Rear Wheel House Moldings, Bright Drip Rail Mouldings and Bright Belt Mouldings.
This was a very popular (higher percentage) option and upgrade to base models - I don't have the numbers in front of me, but you can check CRG for that. ( www.camaros.org )
These mouldings were also found on the RS optioned cars and included in RPO-Z22.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Feb 7th, 08, 09:11 AM
Greg
Thanks Eric, more good info.........
Old May 13th, 08, 11:49 AM
Brad
Yesterday I was looking at a '79 Camaro and noticed this chrome rocker trim piece looked identical to the one on my '68! Can anyone confirm whether or not this is the same part?
Old May 13th, 08, 01:57 PM
Vintage 68's Avatar
John
Question Re: Chrome rocker trim on '68 Camaro
The GM part numbers are different - so the are not 'identical'
Can't answer if they might fit as I don't have length measurements - maybe with some new hole drilling and the correct type clips they might be close ...
The correct type are still available from many sources, so I don't intend to try the later type any time soon
1968 Convertible
Some trucks
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Chrome rocker trim on '68 Camaro
Location
Location
First Name
Human Verification
