| Team Camaro Tech Current Topic: 67 Camaro Steering Column Replacement | ||
| Camaro Tech General Tech Area For best results use specific forums |
I have a question about replacing my stock 67 Steering column with an aftermarket tilt version now that I have switch the shifter from the tree to the floor. I have a power steering. The questions I have are:
1. any suggestion on the supplier 2. and any advise on fit 3. What additional parts will I need to order beside the column to make it work. Thanks. Mark |
| Sponsored Links | ||
Advertisement | ||
If you search here using "ididit" (one of the aftermarket tilt column suppliers), you'll get quite a bit of reading on the swap and what is available and needed.
Eric 69 'vert project big block/TKO 600 RR 68 'vert driver RS clone -- gone! |
I'm doing the column to floor switch next week. I got the Ididit retro tilt column for my 68. It will be the same column for 67. In addition to the column they recommend replacing the U joint.
My Ride: 1968 Camaro SS Clone http://www.flickr.com/photos/booman5...57631164401358 |
I used the ididit. Nice piece. As above replace the u-joint or rag joint. I used a new rag joint but plan to change to a u-joint to take out the last bit of slop.
There shouldn't be any slop in a new rag joint.
Slop was probably a little to much for what I actually meant. There is more give in a rag joint than a solid u-joint. Although slight you can tell the difference.
Been running the Ididit tilt in mine for several years without any problems.
Chris 1968 Camaro SS coupe, Lemans Blue/medium blue interior LS3/T56 Ridetech Suspension http://community.webshots.com/user/130fe |
I am going IdidIt for the tilt its easier then loosing weight :-)
BTW if you need a non tilt column floor shift and you wand to save a few 100.00 PM me |
I got a repro column from either D&R or Classic Industries and it was exactly like stock. Put in a new rag joint and bolted it right up.
67 Yenko Tribute - 427/4SPD/Bolero Red 2010 2SS/RS Camaro - Victory Red with White Rally Stripes http://www.67yenko.com http://www.dive-ids.com http://www.azdivetraining.com |
Thanks for all those who replied. I have another problem needing your expert help. I am also putting in a rack and pinion setup and have been warned of fit issues around the header. I am using a Hedman Header long tube, rack and pinion and an Ididit replacement column with a u joint all from Classics Industries. How do I make the column fit past the header. I talked to several header outfits and non of them stand by their headers using a rack and pinion setup.
#11
I got one from Classic Industries. I don't think it was a repo, I am almost positive it was a rebuild. You would have to ask them.
| Sponsored Links | |
Advertisement | |
