67 Antenna Location - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Feb 22nd, 08, 01:06 PM
Frankrentef's Avatar
Frankrentef Frankrentef is offline
Default 67 Antenna Location
Greetings all,
Hopefully an easy question...
Why do I see some 67 Camaro's with the antenna mounted on the rear (passenger side) while others it's mounted on the front (passenger side) fender?
THNX
67 Camaro RS - 383 Stroker
Factory A/C - Muncie 4 speed
Old Feb 22nd, 08, 01:21 PM
Lost in the 60's Lost in the 60's is offline
Mitch
Default Re: 67 Antenna Location
Right front fender was standard and rear was optional. It was stylish to have it mounted on the rear.
...38 Chev coupe, street rod
...52 Chev 6400, 2 ton flat bed building a car hauler
...62 Impala SS, driver/project
...67 Camaro, ss/rs LA built driver/project
...66 Chevelle SS, Atlanta built 138 driver/project
...66 Malibu hardtop project
...70 Chevelle SS, Canadian documented Z25 project
Old Feb 22nd, 08, 02:09 PM
RS3SDL2MG's Avatar
RS3SDL2MG RS3SDL2MG is offline
Brad
Arrow Re: 67 Antenna Location
one other thing is that the front fender one's were am/fm while the rear mounted antenna is AM ONLY !!
1967 RS 327
Old Feb 22nd, 08, 02:10 PM
Explains why mine is in the rear!
THNX
Old Feb 22nd, 08, 05:53 PM
keypilot's Avatar
keypilot keypilot is offline
Mark
mine has no antenna.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
www.firstgens.com
Old Feb 22nd, 08, 06:20 PM
Mitch
Same here, Mark. I have a hole in the front fender, but the antennae is MIA...
Old Feb 22nd, 08, 07:47 PM
Larry B Larry B is offline
Larry
http://image60.webshots.com/660/2/36...9YlzvqV_ph.jpg
hears a pic of a 68 camaro rear I think 67 are the same
I got it off a junk camaro, it's stock
Larry
Old Feb 22nd, 08, 10:06 PM
Stocker Shocker 1967 z28 Stocker Shocker 1967 z28 is offline
Joey B
rear antenna was for am only. I have one on my recently purchased 1967 z28, yes real 4L code with 17,000 original miles. good luck
Old Feb 23rd, 08, 04:54 AM
RS3SDL2MG's Avatar
Brad
Question Re: 67 Antenna Location
you know the 67 rear antenna is coded on the cowl tag too , wonder why they thought an antenna was important enough to be a seperate option ?
1967 RS 327
Old Feb 23rd, 08, 06:33 AM
67CamaroRS/SS 67CamaroRS/SS is offline
Charlie
I have a 67 with antenna in the rear. Now it is a power unit for am/fm and then I have another antenna mounted between the trunk lid and the rear window trim for satellite radio. The power antenna was the best thing I ever did. I don't have to worry about somebody ripping it off.
Charlie Knudsen 67 Camaro RS/SS 350 TKO 600, 4.10's, AFR 195 Street Heads, Comp 270H, Rhoads Lifters, Crane Ignition, Pertronix Dizzy, Performer RPM Q-Jet, Heavily Modified Q-Jet, Hooker Comp Headers, MagnaFlow 2 1/2", 144 Decibles(Alpine CDA-7998 Head Unit, RF X7 and RF 750X Amps, MB Quart Mid's & High's, Kicker L7 12" Solo Barics)
  #11
Old Feb 23rd, 08, 07:56 AM
keypilot's Avatar
Mark
your lucky mitch, i dont even have a hole! lol
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
www.firstgens.com
  #12
Old Feb 23rd, 08, 04:12 PM
harkz28 harkz28 is offline
Tech Team
Steve
Your fender must have been repalced. The OER repop front right fenders have no antenna hole.
BURN RUBBER
1970 RS/Z28
LT 1 Turbo 400!
  #13
Old Feb 23rd, 08, 04:26 PM
Mitch
I'll bring mine down and we can trade.......... I'm thinking power mounted in the rear also..... Then it won't get in the way of the spoiler.........
  #14
Old Feb 23rd, 08, 05:04 PM
Larry
http://inlinethumb35.webshots.com/13...600x600Q85.jpg
  #15
Old Feb 23rd, 08, 05:39 PM
keypilot's Avatar
Mark
I think it is an original fender, if you look at the right angle you can see where it was. somebody covered it over at some point.
mitch, i'm not sure it will fit in the overhead compartment. getting close, are you excited about the trip??
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
www.firstgens.com
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: 67 Antenna Location
Location
Location
First Name
Human Verification
