| Team Camaro Tech Current Topic: 700R4 Questions--Should I have both Vacuum and Electric Lock-up? | ||
I am swapping to a 700R4 and have learned much from TC and those that have gone before. That said, I still have a question.
I understand that I can do 4th gear lock-up with either vacuum or 12V. Could I or should I do both 12v and vacuum lock-up? With 12V, do I hook the wire from the trans to a cruise control brake light switch and then to a 12V ignition source? Thanks, Brent
1968 RS/SS with a bunch of stuff done to it that I like... |
| Sponsored Links | ||
Advertisement | ||
Lots of folks including myself are just using the 12V lockup. Vacuum lockup control will disengage the TCC clutch when your manifold vacuum drops below a certain level. In other words when you hammer the throttle, the TCC will unlock to give you some torque multiplication. I eventually plan to put a 5 speed manual box in mine and get rid of the 700R4, but otherwise I'd put the vacuum switch in for improved performance.
Reading on in your question....the 12V source should cut off when you apply the brake. Here again, there are lots of folks running without brake switches. What the switch does is help prevent a stall (not to mention improved braking performance) during a panic stop. Otherwise the TCC can remain engaged and attempt to turn the wheels while you're stopping. I'm not sure about using the cruise control switch since I don't know exactly how it's wired, but it's a possibility. One of the more clever tricks I've heard of is to use the existing brake light circuit to trigger a relay that sends 12V to the tranny when the brake is released and opens when the brakes are applied.
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
hey there I am at this stage also what is the options here can anyone help me out thanks
I use a simple momentary pushbutton and a self-latching relay to control my 700R4 lockup solenoid. It is in series with a brake switch, so when I push the lockup button, it locks. When I tap the brake pedal, it unlocks. Very simple, nothing to adjust, it does exactly what I want it to do. It locks up in any gear, so you can reduce slippage whenever you want.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know." Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968 |
Well I have the valve and cc brake switch already but just wanna clear up the wiring procedure
"key on" 12v > CC switch > trans solenoid wire.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler |
| Sponsored Links | |
Advertisement | |
