SBC head/valve size info data base ? - Team Camaro Tech
Thread Tools Display Modes
Old Feb 25th, 08, 08:10 AM
Lost in the 60's Lost in the 60's is offline
Mitch
Default SBC head/valve size info data base ?
I have been trying to find info on different head casting numbers and only come up with mor-tec's site. They don't list valve sizes. Is there a good site that lists valve sizes and whether they came with hardened seats to go with the casting numbers ??
...38 Chev coupe, street rod
...52 Chev 6400, 2 ton flat bed building a car hauler
...62 Impala SS, driver/project
...67 Camaro, ss/rs LA built driver/project
...66 Chevelle SS, Atlanta built 138 driver/project
...66 Malibu hardtop project
...70 Chevelle SS, Canadian documented Z25 project
Old Feb 25th, 08, 01:35 PM
Rogers Performance Rogers Performance is offline
Mike Rogers
Default Re: SBC head/valve size info data base ?
All sbc heads after i think its 75 came with induction harden exhaust seats or have inserts in them. What casting Number are you looking at.
Mike
Automotive Machine Shop
Racing . Stock . Antique
Complete Engine Rebuilding
215-674-5240
www.rogersperformance.com
rogersperformance@msn.com
Old Feb 25th, 08, 03:26 PM
Mitch
The engine in my car has 3986339X heads. The engine was installed as a long block sometime in the late 80's or early 90's. They may already have the hardened seats, but I can't find any solid info on valve size. If they are the same 1.94/1.60 as the 461's I bought I may just keep them for the rebuild. If they are the smaller 1.72's, then I will need to rebuild my 461's.
Old Feb 25th, 08, 04:34 PM
pdq67 pdq67 is offline
Banned
Smile Re: SBC head/valve size info data base ?
I will try to help.
All early 265's, all 283's except the 315hp/283 jobber, lo-po 305's, 307's, 327's and 350's came w/ 1.72"/1.50" valves. 250hp on down 327's and 2-barrel 350's here. I flat don't know if GM ever installed 1.72"/1.50" valve heads on the 400's or not?? Sorry...
The 262 and I think 267 and maybe some lo-po 305's came w/ 1.72"/1.38" valves.
The 315hp/283 and the average hp engines from 275 and 300hp/327's, the 295 and 300hp/350's and 400's came w/ 1.94"/1.50" valves, w/ the early 400's, ('71 and '72), also using 1.94"/1.60" valves.
The hi-po 290hp/302, 350/365/375hp/327's and 330/350/360/370hp/350's came w/ 2.02"/1.60" valves!
And last, the hi-po 305HO jobbers came w/ 1.84"/1.50" valves.
And as said earlier, the hard seats kicked in a couple a years before unleaded gasoline showed up, somewhere around late '71 to early '73 or so.
How far off am I guys??
pdq67
Old Feb 25th, 08, 04:37 PM
Mike Rogers
Being they came on 307 and 350 i,am going to say it has 1.84 1.500 valve size. I can,t be sure 100 %. Your 461 will pick your engine up in compression.
Mike
215-674-5240
Old Feb 25th, 08, 05:28 PM
Mitch
Yeah, I figured since they were listed for the 307 that they would be for a 2GC 350 and have a smaller valve than a 4MV head.
Thru the plug hole, it looks like the pistons are flat top. I have another block that I am going to build with .030 dish pistons for the 461 heads. I was just curious if the 339X heads were worth considering. I guess I still need to spend the dough to upgrade the 461's.
Thanks.....
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: SBC head/valve size info data base ?
Location
Location
First Name
Human Verification
